| Re: 3D Max Shapeways Calculator BETA 10 [message #28408 is a reply to message #28396 ] Tue, 31 May 2011 08:40 UTC |
The path max gives you should exist,
normally it starts with "c:\users\" (yours is missing an S)
Perhaps you made a typo ? I just copied the path you gave me, but it should be the path max shows in the error.
You can try to enable hidden files to navigate easier.
[Updated on: Tue, 31 May 2011 11:56 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
| Re: 3D Max Shapeways Calculator BETA 10 [message #28419 is a reply to message #3223 ] Tue, 31 May 2011 13:13 UTC |
I just checked it out and when I docked the panel it basically maximized and I couldn't see any of the viewports, and I couldn't figure out how to undock it.
| Re: 3D Max Shapeways Calculator BETA 10 [message #28421 is a reply to message #28419 ] Tue, 31 May 2011 13:30 UTC |
EDIT
I have fixed the beta10 file. It should be only be able to float, dock left and right now.
That's weird
Did you dock it manually at the top or bottom?
Usually you can right click the docking bar (the double lines to the top or left of the calculator) to choose docking or float options.
It always used to dock at the left by default, the basics did not change.
Did you update/restore the config?
Perhaps re-running the script?
Can you try the edit config and find the "docking" value at the bottom of the file, it can be either left or right. Any other value should float it.
[Updated on: Tue, 31 May 2011 13:38 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
| Re: 3D Max Shapeways Calculator BETA 10 [message #28425 is a reply to message #28421 ] Tue, 31 May 2011 15:10 UTC |
Thanks for updating it. I'll try it in a moment.
I manually docked it by dragging it to the left side of Max.
There was no docking bar for me to right-click on or drag the panel away from the left.
| Re: 3D Max Shapeways Calculator BETA 10 [message #32793 is a reply to message #32791 ] Tue, 16 August 2011 11:32 UTC |
Hmm, strange..
Attached a version (b11) that hopefully fixes that behavior.
EDIT: For posterity sake this post will keep Beta11 attached.
Current latest is V1.1 which got a big overhaul, but it breaks compatibility with the old config.
There were just too many changes in materials and new parameters to keep it compatible.
[Updated on: Fri, 06 July 2012 21:45 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
