Home » Support » 3D Design » Color Printing texture problem
Color Printing texture problem [message #38525] Mon, 14 November 2011 10:40 UTC Go to next message
avatar galladur  is currently offline galladur
Hi everybody !
I try desperately to import a coloured model to make a 3D color printing.... but it seems like a crusade to do this.
I make my model with Zbrush, I paint it, export it in .obj with texture....
Then I take a look in 3DS to be sure it's ok ... and it is !
So I Open Meshlab and I import my mesh.... here is the result :
http://www.lesazes.com/Redforge/ZBrush/Bruce_Willis/MESHLAB.JPG
Everything is all right !
So I make "export mesh as...." and I choose VRML format....
I make my .zip and upload it on Shapeways...
And Here is the result on the site :
http://www.lesazes.com/Redforge/ZBrush/Bruce_Willis/Resultat_shapeways.JPG
PLEASE HELP !!!!
I don't understand what's wrong !
Re: Color Printing texture problem [message #38579 is a reply to message #38525 ] Mon, 14 November 2011 23:27 UTC Go to previous messageGo to next message
Meshlab doesn't work for me either exporting .obj as VRML, so I use Accutrans3D which works flawlessly.
Re: Color Printing texture problem [message #38607 is a reply to message #38579 ] Tue, 15 November 2011 08:58 UTC Go to previous message
Re !!!
I've found the solution !!!
I've tried just to make it with an 3DS export in WRL after a set of uv on the model in 3DS..... and it works Smile
@stop4stuff : thx for the info
@Peter : thx for your msg too (I've tried a answer but i don't know if it worked)
[Updated on: Tue, 15 November 2011 09:02 UTC]
Previous Topic:Weird Upload Issue: Model is 3.8 cm x 0 cm x 0 cm
Next Topic:STL + Image => Shapeways colored sandstone print ?
