| Small Vehicles? [message #38488] Sun, 13 November 2011 15:16 UTC |
Hey All,
I need some advice about printing Vehicles.
So far i already know is that i need to use
http://www.shapeways.com/materials/frosted_detail
And seen some cool Model Train recreations and wondering
What material i can use best. I already sended in a Omega Pendant but on White, Strong & Flexible Material because its just for testing first!
I also seen people prints the model in separate objects. like detaching all wheels and some parts. and after all glue them together!
I need some advice from model builders.
Some mesh info how i work is also on my blog
http://blog.e-studios.eu/
See designs below id like to print.
These meshes are pretty complex in 3d but have to Boolean some objects later on!
[Updated on: Sun, 13 November 2011 15:17 UTC] Keeping Making Awesome
~ Looking for Freelance Job / Permanent Job! "The Netherlands"
| Re: Small Vehicles? [message #38501 is a reply to message #38488 ] Sun, 13 November 2011 21:32 UTC |
Frosted Ultra Detail requires the least clean up and provides the best detailing on small models.
Normally the seperation of parts is to help with clean up (washing, sanding, smoothing etc) or painting. So splitting a part is best if the part will get in the way during painting or cleaning, if it isn't in the way you should just leave it attached.
I only use WSF on small models if printing in FUD is too expensive. WSF is difficult to sand and is also porous so it will often absorb any paint or glue. But it is much cheaper than other materials.
Hope this helps!
Kindest Regards,
Jack
| Re: Small Vehicles? [message #38508 is a reply to message #38501 ] Mon, 14 November 2011 00:37 UTC |
Well I was planning to keep it white like the render and maybe maybe maybe a other color but not planning to paint it high detailed. Just wanto test a 3d print of some fav models i made while back ago.
My plan was to split all objects that has to be splitted.
like wheels that kind of things and when its printed put it together like a DIY MODEL KIT.
Ill try something out and post a render of the mesh
| Re: Small Vehicles? [message #38509 is a reply to message #38508 ] Mon, 14 November 2011 01:12 UTC |
So this is the mesh total splitted. Well its low poly but i just want to have the low poly mesh printed.
