Home » Support » 3D Applications » Inverted normals
Inverted normals [message #3151] Sat, 28 February 2009 20:50 UTC Go to next message
avatar dfbills  is currently offline dfbills
I'm new at this, but trying to use sketchup 7 to do a very simple tray. I keep getting Inverted normals errors, but I can't locate them. Can someone help?
Re: Inverted normals [message #3152 is a reply to message #3151 ] Sat, 28 February 2009 21:18 UTC Go to previous messageGo to next message
avatar daddymack  is currently offline daddymack
Hi dfbills, the problem appeared that many polygons in your mesh were not properly attached
I've left the original in tact and made a cleaner version in the attached file
  • Attachment: redo tray.DAE
    (Size: 17.84KB, Downloaded 107 time(s))
Re: Inverted normals [message #3154 is a reply to message #3152 ] Sun, 01 March 2009 00:19 UTC Go to previous messageGo to next message
I'm still getting inverted normals- even on your file. Ugh.
Re: Inverted normals [message #3156 is a reply to message #3154 ] Sun, 01 March 2009 01:32 UTC Go to previous message
the file I upped had both your original and my fixed one because I wasn't sure how perfect you wanted it to be regarding measurement (I made it by eye)
here's a clean one which I tested first;)
http://www.shapeways.com/model/19659/tray_test.html
Check the measurements first tho mate;)
Previous Topic:VectorWorks
Next Topic:Blender: How to create meshes without tons of n-manifolds
