simple task for someone
simple task for someone [message #37431] Thu, 27 October 2011 04:25 UTC Go to next message
avatar yxalitis  is currently offline yxalitis
Hi Guys,
New to this forum, and looking for a 3D model of the Millennium Falcon to print, but this only needs to be a basic, low-poly model, as I want it at 1/2256 scale (about 2.4cm).
Happy to pay a few bucks, but I do think this is a fairly easy request.
At this size, it can be solid, making the whole back-plane nonsense a non issue.
Re: simple task for someone [message #37464 is a reply to message #37431 ] Thu, 27 October 2011 14:35 UTC Go to previous messageGo to next message
avatar invidos  is currently offline invidos
Should it also be textured?
edit:Far from the best that I've done, but if you want it you can have it for free, just not sure how to set the size of the print
http://i.imgur.com/n8VM0l.jpg
[Updated on: Thu, 27 October 2011 18:32 UTC]
Re: simple task for someone [message #37497 is a reply to message #37464 ] Thu, 27 October 2011 23:01 UTC Go to previous messageGo to next message
That's pretty much EXACTLY what I want.
Thanks heaps!!
How do I go about getting that printed?
Re: simple task for someone [message #37537 is a reply to message #37497 ] Fri, 28 October 2011 16:21 UTC Go to previous messageGo to next message
I have no idea of how this works.... I guess I can send you the obj file. but there is sort of a problem with scale, can't really understand how to get it 2.4cm long
anyways, attached the file to this post.
Re: simple task for someone [message #37545 is a reply to message #37537 ] Fri, 28 October 2011 17:37 UTC Go to previous messageGo to next message
tried loading in netfabb but it failed. Normally this is what I would use to rescale to a specific size.
Re: simple task for someone [message #37547 is a reply to message #37545 ] Fri, 28 October 2011 18:16 UTC Go to previous messageGo to next message
do you have any idea of why it failed?
Re: simple task for someone [message #37549 is a reply to message #37547 ] Fri, 28 October 2011 18:48 UTC Go to previous messageGo to next message
error in the file. other programs I have will open with warning but don't know how to scale in those programs.
Re: simple task for someone [message #37550 is a reply to message #37549 ] Fri, 28 October 2011 18:54 UTC Go to previous messageGo to next message
Here you go. Maniged to convert to STL, fix errors and resize to 2.4cm long.
lost most of the detail when correcting file it seems
  • Attachment: mf.stl
    (Size: 128.99KB, Downloaded 32 time(s))
[Updated on: Fri, 28 October 2011 18:54 UTC]
Re: simple task for someone [message #37551 is a reply to message #37550 ] Fri, 28 October 2011 18:57 UTC Go to previous messageGo to next message
here is without fixing the errors. shapeways will probably fix to be correct but may not.
Just tried it. Works well:
http://www.shapeways.com/model/367575/mf.html?gid=ug
Not for sale as it is not my model. Will remove in a week,
    (Size: 262.88KB, Downloaded 33 time(s))
[Updated on: Fri, 28 October 2011 19:02 UTC]
Re: simple task for someone [message #37552 is a reply to message #37431 ] Fri, 28 October 2011 19:00 UTC Go to previous messageGo to next message
I was able to open in meshlab, and scale down to 2.4cm. Took me a minute to figure out how to do it. http://www.shapeways.com/model/367539/millenium_falcon_ml.ht ml?key=6adf6328dc57a97c71abf5ba1887c192
The file is attached
Re: simple task for someone [message #37562 is a reply to message #37552 ] Fri, 28 October 2011 20:49 UTC Go to previous messageGo to next message
only thing I find odd is that I did scale it in 3ds max to be 2.4 cm, but that for some reason did not work when I tried to upload it....
Re: simple task for someone [message #37578 is a reply to message #37431 ] Fri, 28 October 2011 23:36 UTC Go to previous messageGo to next message
Wow, and I mean WOW, you guys are AWESOME!!
I will upload now, thanks so much!
Re: simple task for someone [message #37665 is a reply to message #37562 ] Mon, 31 October 2011 13:38 UTC Go to previous message
invidos wrote on Fri, 28 October 2011 20:49
Well some how the model came out 24 cm (I had to scale it down to 10%)
Previous Topic:Plummer-Fernandez seeks mesh repair-person
Next Topic:Quid Pro Quo. Seeking Visionary Designers For Our Porcelain Casting Co.
