Home » Community » Work in progress » V-Heart Cookie Cutter
V-Heart Cookie Cutter [message #36487] Wed, 12 October 2011 10:35 UTC Go to next message
avatar veganerdism  is currently offline veganerdism
Hi
I hope you can help me. This is my first 3D-project and I'm having some difficulties.
I'm using Cinema 4D R.13 and Illustrator. I know my Adobe Creative Suit pretty well and tried to understand C4D, too. More or less.
I'm working on a cookie cutter. I have the model now a I want it to be. Now I have some problems/questions:
1. In the shapeways tutorial for C4D it says:
Quote:
7. Make your geometry a single object, the Objects>Modeling>Connect Object
8.Drag the elements you want to connect into Connect Object icon using the Object window to the right of the screen.
I'm not sure if I did this correctly.
http://i33.photobucket.com/albums/d55/marlies01/Tree.jpg
2. I don't know how to resize it properly so that it will be approximately 7x7 cm
3. What is the minimum wall thickness I should use for a cookie cutter if I produce it in "White, Strong & Flexible?"
I attached my C4D-file and would be really glad if someone could find the time and have a look at what I did. Thank you all!
edit: I figured it out all by myself Wink
[Updated on: Wed, 12 October 2011 19:57 UTC]
Re: V-Heart Cookie Cutter [message #36488 is a reply to message #36487 ] Wed, 12 October 2011 10:38 UTC Go to previous messageGo to next message
One question solved:
Quote:
Minimum wall thickness
Strong & Flexible materials = 0.7 mm. We do however advise to use at least 1 or 2 mm, depending on the size of the area
Grey Robust + White, Transparent & Black detail = 1mm
Alumide = 1.5mm
Stainless Steel + Full Color Sandstone + Glass = 3 mm
Re: V-Heart Cookie Cutter [message #36490 is a reply to message #36488 ] Wed, 12 October 2011 11:03 UTC Go to previous messageGo to next message
If I try to upload it, I get the error message:
Quote:
Unfortunately, we were not able to process and thus print
your product. The error message was:
empty output
Re: V-Heart Cookie Cutter [message #36497 is a reply to message #36490 ] Wed, 12 October 2011 12:29 UTC Go to previous messageGo to next message
I started over again and made a whole new version with the right sizes. I'm completely satisfied with how it looks and would want to produce it as it is.
But I'm nearly crying because I just can't get it to "connect to one object." Everything I tried turned out a complete mess. Party were missing or deformed.
I tried every video tutorial I could find and now I'm close to giving up.
Could you help me please?
The new version is attached.
[Updated on: Wed, 12 October 2011 19:56 UTC]
Re: V-Heart Cookie Cutter [message #36508 is a reply to message #36488 ] Wed, 12 October 2011 14:42 UTC Go to previous message
Where does it still say sandstone is 3mm?
Edit: OK, found it. The chart with all materials says 3mm, the sandstone page says 2mm. *sigh*
[Updated on: Wed, 12 October 2011 14:44 UTC]
Previous Topic:Flexed Text Ring
Next Topic:want to print in glass but can't!
