| Rally & race car miniatures [message #36476] Wed, 12 October 2011 08:34 UTC |
I build miniature replica race and rally cars. Mostly in scale 1:18.
Starting from a base diecast model, I make all changes to the base model so it becomes an exact replica of an excisting race of rally car.
Hopefully Shapeways can print some wheels, spotlights and other details I designed.
Have a look on my website: http://www.safetyfastrallyclub.nl/UK/Scale%20Models%20and%20 miniature%20cars%20projectsUK.html
Maarten
Maarten
| Re: Rally & race car miniatures [message #36481 is a reply to message #36476 ] Wed, 12 October 2011 09:54 UTC |
Welcome Maarten,
Are there any other websites or online forums you visit surrounding these miniatures?
They look amazingly accurate.
| Re: Rally & race car miniatures [message #36515 is a reply to message #36483 ] Wed, 12 October 2011 15:49 UTC |
Resin is typical for final parts, for cost and finish reasons, don't discard it so fast. Original parts sometimes start as 3D print (or CNC, brother of 3D print), but final ones are resin copies. You could print only one (to save money, as hollow as possible) wheel hub, retouch it, make molds and cast as many as you need. This Corvette guy seems to do exactly that. Pro companies have been doing it even for longer, they just stood silent about the secret sauce (Original CAD files from Ferrari? Woah!).
You will have to smooth WSF like Alumide, they are pretty much the same thing just different dust loaded in the machine. So back to resin casting from 3D printed molds, maybe UD to reduce retouch time. Take a look at old posts in post process subforum.
| Re: Rally & race car miniatures [message #36841 is a reply to message #36515 ] Tue, 18 October 2011 11:16 UTC |
Turning this model into a resin might be a good idea.
First I have to sort out my payment. It seems to be lost some how.
Maarten
| Re: Rally & race car miniatures [message #37667 is a reply to message #36515 ] Mon, 31 October 2011 14:03 UTC |
Today I received my first order. The Tripmaster (a divice to measure distance during classic rallies) is absolutely fantastic.
The wheels however aren't as smooth as I hoped. OK, my expectations were a bit too high probably. Time for a secound test!
Maarten
| Re: Rally & race car miniatures [message #38440 is a reply to message #38433 ] Sat, 12 November 2011 08:18 UTC |
Your Ferrari models are looking superb!
Looking forward to see your 3D prints as well.
Maarten
| Re: Rally & race car miniatures [message #38450 is a reply to message #38440 ] Sat, 12 November 2011 16:16 UTC |
My wheels should arrive this week. I'll post some pictures when I get them. I'm also thinking of having rearviewmirrors printed. There is a constant need for those. But that would probably need to be done in "white detail" to get a smoother finish.
What 3D program do you use? With the AutoCAD program I use, it's very hard to get smooth flowing lines, other than circles or ellipses, where I want them.
Kind regards,
Otto.
| Re: Rally & race car miniatures [message #38453 is a reply to message #38451 ] Sat, 12 November 2011 16:46 UTC |
O.K. So maybe no rearviewmirrors then. I'll see it when my wheels come in.
The Alfa looks really good!
[Updated on: Sat, 12 November 2011 16:49 UTC]
| Re: Rally & race car miniatures [message #38461 is a reply to message #38453 ] Sat, 12 November 2011 17:37 UTC |
The mirrors are resonably flat. I guess you wouldn't have the same problems as with the wheels.
As far as I can see, curves in the virtical direction give problems. The curving of the inner part of the wheel is not very smooth. Well, you'll see when your wheels arrive.
Maarten
| Re: Rally & race car miniatures [message #38950 is a reply to message #38461 ] Mon, 21 November 2011 10:17 UTC |
Hello Maarten,
Last Friday my wheels arrived.
I'm pretty pleased wih the result. The surface is a little rough, but for wheels or other components like engines or axle's I's good enough. I think it also helps that the curve in the centre of my wheels is quitte shallow. I painted the wheels with a metalic paint. This, in combination with the rough surface, gives a very "sparkly" effect. Maybe a flat gray color is beter.
Oh, and I blundered with the design. There should be 10 holes in the wheel. I've got 12. I'll live with it, for the time being. If I dont like it, I'll fit them to an Alfa GTA.
I think I could scrape of some more material of the wheel. I made the centre quitte thick to make it strong on this first set. It saves money, but it's also a nice design challange to get a strong wheel, with the least amount of material.
First thing I want to do now, is get my DeDion axle printed, but I need to do some more work on the drawing.
Kind regards,
Otto.
[Updated on: Mon, 21 November 2011 10:19 UTC]
| Re: Rally & race car miniatures [message #46239 is a reply to message #39059 ] Sat, 31 March 2012 13:24 UTC |
Hello Maarten,
It's been a while, but last friday I ordered my second shapeways product. I was working on a DeDion Axle for a Ferrari 250TR. But the Hotwheels is quitte a crude model, so I decided to do the whole chassis.
This first chassis has a live rear axle. It's the simplest version of the TR-chassis. If this one turns out right, I'll also order a TR58-chassis (with the DeDion) and then its quitte easy to adapt the drawing for a TR59, TR59/60, and a TRi60. They're all a little different, but basicly the same.
Have you tried anything new?
| Re: Rally & race car miniatures [message #47867 is a reply to message #46239 ] Fri, 04 May 2012 13:07 UTC |
Hi Otto,
Nope, haven't tried anything new. A friend of mine is making the drawings so that makes it a bit compicated to start a project.
Maarten
