Home » Support » 3D Applications » Anybody use gmax?
Anybody use gmax? [message #36230] Sun, 09 October 2011 03:23 UTC Go to next message
avatar maketshi  is currently offline maketshi
It seems like a decent modeling program, and it's free, but I haven't seen many other people working with it.
I can get .STL files by exporting .MD3, converting to .obj in lithunwrap, and cleaning up and exporting to .STL in Meshlab.
Problem is, I want to hollow out my models, and the tutorial I tried for hollowing out models with meshlab didn't produce a useable mesh when I tried to boolean subtract a hole in gmax.
in netfabb, the boolean results look good, but netfabb basic doesn't let me finalize the boolean operation, it just shows it to me, and like I said, it looks like what I want.
Gmax seems to see the inner surface as flipped.
This is the tutorial I followed:
https://sites.google.com/site/3dprintfaq/workflows/hollowing -a-model
Re: Anybody use gmax? [message #36787 is a reply to message #36230 ] Mon, 17 October 2011 16:16 UTC Go to previous messageGo to next message
maketshi wrote on Sun, 09 October 2011 03:23
I think there is greater support for Blender in 3D Printing applications, it is also a free program. May be worth giving that a go?
Kindest Regards,
Jack
Re: Anybody use gmax? [message #36794 is a reply to message #36230 ] Mon, 17 October 2011 19:13 UTC Go to previous messageGo to next message
No experience with gmax, but you can now upload obj straight to shapeways. Do you have geometry connecting the outside geometry to the internal geometry? Shapeways software will automatically remove internal geometry that is not connected to the external geometry.
Re: Anybody use gmax? [message #36836 is a reply to message #36794 ] Tue, 18 October 2011 08:21 UTC Go to previous messageGo to next message
I figured out how my inner surface was getting flipped. I had not unchecked "Unify Normals" in the Import DXF dialog box when I was importing into gmax.
I tried several methods to generate geometry to connect the inside and outside surfaces, with no luck. Eventually, I just tried using a Boolean Union between the hole in the object and a torus.
But when I uploaded it to shapeways, the error checking algorithm filled it in solid again.
Re: Anybody use gmax? [message #36860 is a reply to message #36230 ] Tue, 18 October 2011 14:49 UTC Go to previous messageGo to next message
Does it have a boolean subtract function? then you just draw a cylinder connecting them and subtract it from the geometry. It's difficult to advise not knowing the software.
Re: Anybody use gmax? [message #36895 is a reply to message #36860 ] Tue, 18 October 2011 18:36 UTC Go to previous message
It does have boolean subtraction, but for some reason it doesn't leave behind any geometry connecting the surfaces.
It does when I use boolean subtraction on two simple primitives, just not when I subtract a primitive from my model.
I tried doing the boolean subtraction in Blender, but it crashed. I'm getting a new video card to replace my on-board video soon. Hopefully then I will be able to use Blender.
[Updated on: Tue, 18 October 2011 18:38 UTC]
Previous Topic:Blender modifer
Next Topic:problem with boolean
