Home » Support » 3D Design » how does this real lamp neck works?? any idea's?
how does this real lamp neck works?? any idea's? [message #35924] Wed, 05 October 2011 12:57 UTC Go to next message
avatar janis  is currently offline janis
hi
well i'm about 2/3weeks thinking of how it works..
and i don't have any clue..
you can make a neck but it will go down to eath because of the gravity force..
and on the photo it will be set on the position you want..
any idea's how this Technic works and the name for it?
gr.
[Updated on: Wed, 05 October 2011 12:57 UTC]
Re: how does this real lamp neck works?? any idea's? [message #35926 is a reply to message #35924 ] Wed, 05 October 2011 13:19 UTC Go to previous messageGo to next message
In german it's called "Schwanenhals" (gooseneck?), but I don't know how it works.
Re: how does this real lamp neck works?? any idea's? [message #35973 is a reply to message #35926 ] Wed, 05 October 2011 19:21 UTC Go to previous messageGo to next message
aaah ok thank you Smile
danke da fur.
well now i need to know how it works hahah...
gr.
Re: how does this real lamp neck works?? any idea's? [message #35974 is a reply to message #35926 ] Wed, 05 October 2011 19:28 UTC Go to previous messageGo to next message
Gooseneck is a valid name. The metal part is a spiral of metal sheet profile, very tight and overlapping, so internal friction keeps the shape if the load is small. Others just have a flexible metal wire inside, with external ribbed cover.
Re: how does this real lamp neck works?? any idea's? [message #35975 is a reply to message #35974 ] Wed, 05 October 2011 19:33 UTC Go to previous messageGo to next message
uuu.. is it possible to make it in 3d and print it?
is it possible that can draw it, because i'm not totally following..
gr.
Re: how does this real lamp neck works?? any idea's? [message #35976 is a reply to message #35924 ] Wed, 05 October 2011 19:43 UTC Go to previous messageGo to next message
It definitely wouldn't be easy to print something with enough clearance not to bind, but tight enough to have rigidity in one piece. maybe if you make pieces that snapped together with a hole up the middle for the cable to run through.
Re: how does this real lamp neck works?? any idea's? [message #35980 is a reply to message #35975 ] Wed, 05 October 2011 19:58 UTC Go to previous message
Hi Janis,
In principle it is not a lot different to this, but it would take a fair bit of tinkering to make it work as a one piece print... it could probably be done quite easily with snap fit ball joint type parts as a multi-piece print though.
Previous Topic:Converting Matrix into CAD drawing
Next Topic:Errors Uploading Models
