Gallery 3D Viewer
Discussion in 'Bug Reporting' started by minisumo, Feb 9, 2009.
  1. minisumo
    minisumo Member
    At home (on Vista Personal) via Crome and Explorer I seem to have a problem with the 3D viewer. It appears to start loading the applet, it asks for a conformation on certificates, there's a flash of a message box then nothing.
    Work with Explorer on XP, I see a spinning model...
    Does any one know of any Java or Applet version problem on Vista?
    Many thanks,
    Colin
  2. 4808_deleted
    4808_deleted Member
    We test the code daily with Vista, both IE and Firefox, but not with Chrome or Opera. Macs we use Firefox and Safari, while linux with just Firefox. Our daily development machines are all Vista, so we'd be pretty quick to know if there was a problem with it. If you are able to, can you locate and post the java console messages that are being written out. That may give us a clue as to what is going on.
  3. 16672_deleted
    16672_deleted Member
    There are some unimpressive problems with Java in Chrome, so it may not be surmountable until they've fixed it. For too long after the first release, Java would not load at all under any circumstances.
    Chrome uses the windows Safari renderer; if you're able to test Safari in Vista, it may help pin down the problem.
  4. minisumo
    minisumo Member
    Is this something that will be logged for a user by default, or how would I turn the log on? What's its likely name and location?
    I'm happy to help where I can.
    Best regards,
    Colin
  5. robert
    robert Member
    Hi Colin,
    Normally you would have a java icon in your taskbar. If you right click on it you can select the java console.
    Best regards,
    Robert
  6. minisumo
    minisumo Member
    Thanks, found it.
    Trouble is I'm just getting the console open when it disappears :eek:
  7. robert
    robert Member
    Ok. That is a challenge. :)
    Another option is to go to Control Panel and select Java. There you can enable the console to appear on startup. That will help.
    Best regards,
    Robert
  8. minisumo
    minisumo Member
    Great, got it. Enabled the log, do you need the trace too?
    Code:
    <?xml version="1.0" encoding="windows-1252" standalone="no"?>
    <!DOCTYPE log SYSTEM "logger.dtd">
    <log>
    <record>
      <date>2009-02-15T19:17:34</date>
      <millis>1234725454689</millis>
      <sequence>0</sequence>
      <logger>sun.plugin</logger>
      <level>FINE</level>
      <class>com.sun.deploy.util.LoggerTraceListener</class>
      <method>print</method>
      <thread>10</thread>
      <message>JNLPAppletLauncher: static initializer
    </message>
    </record>
    <record>
      <millis>1234725454690</millis>
      <sequence>1</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>os.name = windows vista
    </message>
    </record>
    <record>
      <sequence>2</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>nativePrefix =   nativeSuffix = .dll
    </message>
    </record>
    <record>
      <millis>1234725454691</millis>
      <sequence>3</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>tmpRootDir = C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845
    </message>
    </record>
    <record>
      <sequence>4</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Applet.init
    </message>
    </record>
    <record>
      <sequence>5</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>subapplet.classname = udesign.UDesignApplet
    </message>
    </record>
    <record>
      <sequence>6</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>subapplet.displayname = Shapeways Viewer Applet
    </message>
    </record>
    <record>
      <sequence>7</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>subapplet.image = https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg
    </message>
    </record>
    <record>
      <millis>1234725454745</millis>
      <sequence>8</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Applet.start
    </message>
    </record>
    <record>
      <date>2009-02-15T19:17:37</date>
      <millis>1234725457237</millis>
      <sequence>9</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234725457241</millis>
      <sequence>10</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>os.arch = x86
    </message>
    </record>
    <record>
      <millis>1234725457975</millis>
      <sequence>11</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\jogl-natives-windows-i586.jar
    </message>
    </record>
    <record>
      <millis>1234725457993</millis>
      <sequence>12</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>validateCertificates:
    </message>
    </record>
    <record>
      <millis>1234725457994</millis>
      <sequence>13</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>VALIDATE: jogl.dll
    </message>
    </record>
    <record>
      <date>2009-02-15T19:17:38</date>
      <millis>1234725458049</millis>
      <sequence>14</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>VALIDATE: jogl_awt.dll
    </message>
    </record>
    <record>
      <millis>1234725458050</millis>
      <sequence>15</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>VALIDATE: jogl_cg.dll
    </message>
    </record>
    <record>
      <millis>1234725458054</millis>
      <sequence>16</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>extractNativeLibs:
    </message>
    </record>
    <record>
      <sequence>17</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>EXTRACT: jogl.dll(jogl)
    </message>
    </record>
    <record>
      <millis>1234725458060</millis>
      <sequence>18</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>EXTRACT: jogl_awt.dll(jogl_awt)
    </message>
    </record>
    <record>
      <millis>1234725458063</millis>
      <sequence>19</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>EXTRACT: jogl_cg.dll(jogl_cg)
    </message>
    </record>
    <record>
      <millis>1234725458375</millis>
      <sequence>20</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\gluegen-rt-natives-windows-i586.jar
    </message>
    </record>
    <record>
      <millis>1234725458426</millis>
      <sequence>21</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>22</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>VALIDATE: gluegen-rt.dll
    </message>
    </record>
    <record>
      <millis>1234725458430</millis>
      <sequence>23</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>24</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>EXTRACT: gluegen-rt.dll(gluegen-rt)
    </message>
    </record>
    <record>
      <date>2009-02-15T19:17:50</date>
      <millis>1234725470384</millis>
      <sequence>25</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Message: VERSION: 1.2.4
    </message>
    </record>
    <record>
      <date>2009-02-15T19:17:51</date>
      <millis>1234725471081</millis>
      <sequence>26</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>******** Creating mesh editor *
    </message>
    </record>
    <record>
      <millis>1234725471191</millis>
      <sequence>27</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>JNLPAppletLauncher.loadLibrary("jogl")
    </message>
    </record>
    <record>
      <sequence>28</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845\jln25846\jogl.dll
    </message>
    </record>
    <record>
      <date>2009-02-15T19:17:52</date>
      <millis>1234725472124</millis>
      <sequence>29</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>The selected editor is udesign.editor.mesh.MeshEditor[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    </message>
    </record>
    <record>
      <millis>1234725472189</millis>
      <sequence>30</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>JNLPAppletLauncher.loadLibrary("jogl_awt")
    </message>
    </record>
    <record>
      <millis>1234725472190</millis>
      <sequence>31</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845\jln25846\jogl_awt.dll
    </message>
    </record>
    <record>
      <millis>1234725472566</millis>
      <sequence>32</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>OpenGL details:
    </message>
    </record>
    <record>
      <millis>1234725472567</millis>
      <sequence>33</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Card vendor: ati technologies inc.
    </message>
    </record>
    <record>
      <sequence>34</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Spec Version: 2.0.6479 Release
    </message>
    </record>
    <record>
      <sequence>35</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>Renderer: ATI Radeon Xpress 1250
    </message>
    </record>
    <record>
      <sequence>36</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>High-resolution shaders enabled
    </message>
    </record>
  9. robert
    robert Member
    Hi Minisumo,
    Thanks for our patience! This is really helpful!
    Yes, we need the trace log also.
    Best regards,
    Robert
  10. minisumo
    minisumo Member
    Another try :)
    regards,
    colin
    Log File:
    Code:
    <log>
    <record>
      <date>2009-02-17T18:13:46</date>
      <millis>1234894426996</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access value sun.
    </message>
    </record>
    <record>
      <millis>1234894426997</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access new value sun.,com.sun.javaws
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access value sun.,com.sun.javaws
    </message>
    </record>
    <record>
      <millis>1234894426998</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access new value sun.,com.sun.javaws,com.sun.deploy
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition value null
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition new value com.sun.javaws
    </message>
    </record>
    <record>
      <millis>1234894426999</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition value com.sun.javaws
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition new value com.sun.javaws,com.sun.deploy
    </message>
    </record>
    <record>
      <date>2009-02-17T18:13:47</date>
      <millis>1234894427000</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition value com.sun.javaws,com.sun.deploy
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access value sun.,com.sun.javaws,com.sun.deploy
    </message>
    </record>
    <record>
      <millis>1234894427001</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.access new value sun.,com.sun.javaws,com.sun.deploy,org.mozilla.jss
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
    </message>
    </record>
    <record>
      <millis>1234894427002</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@276af2
    </message>
    </record>
    <record>
      <millis>1234894427003</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/applet-launcher/applet-launcher.jar, version: null]
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/applet-launcher/applet-launcher.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net:80/ with proxy=DIRECT
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/applet-launcher/applet-launcher.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894427004</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/applet-launcher/applet-launcher.jar : null
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/applet-launcher/applet-launcher.jar
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Accessing keys and certificate in Mozilla user profile: null
    </message>
    </record>
    <record>
      <millis>1234894427005</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loading Root CA certificates from C:\Program Files\Java\jre6\lib\security\cacerts
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loaded Root CA certificates from C:\Program Files\Java\jre6\lib\security\cacerts
    </message>
    </record>
    <record>
      <millis>1234894427006</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loading Deployment certificates from C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loaded Deployment certificates from C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loading certificates from Deployment session certificate store
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Loaded certificates from Deployment session certificate store
    </message>
    </record>
    <record>
      <millis>1234894427008</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Validate the certificate chain using CertPath API
    </message>
    </record>
    <record>
      <millis>1234894427009</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Obtain certificate collection in Root CA certificate store
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: The CRL support is disabled
    </message>
    </record>
    <record>
      <millis>1234894427010</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: The OCSP support is disabled
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: No timestamping info available
    </message>
    </record>
    <record>
      <millis>1234894427011</millis>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Checking if certificate is in Deployment denied certificate store
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Checking if certificate is in Deployment permanent certificate store
    </message>
    </record>
    <record>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894427012</millis>
      <sequence>37</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>38</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894427013</millis>
      <sequence>39</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>tmpRootDir = C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101
    </message>
    </record>
    <record>
      <sequence>40</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Applet loaded.
    </message>
    </record>
    <record>
      <sequence>41</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Applet resized and added to parent container
    </message>
    </record>
    <record>
      <millis>1234894427014</millis>
      <sequence>42</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 1035960 us, pluginInit dt 1513314 us, TotalTime: 2549274 us
    </message>
    </record>
    <record>
      <sequence>43</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894427015</millis>
      <sequence>44</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>45</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>46</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>47</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry not found [url: https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg, version: null]
    </message>
    </record>
    <record>
      <millis>1234894427016</millis>
      <sequence>48</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg with proxy=DIRECT
    </message>
    </record>
    <record>
      <sequence>49</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com:80/ with proxy=DIRECT
    </message>
    </record>
    <record>
      <sequence>50</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894427017</millis>
      <sequence>51</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Applet initialized
    </message>
    </record>
    <record>
      <sequence>52</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@276af2
    </message>
    </record>
    <record>
      <sequence>53</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Applet made visible
    </message>
    </record>
    <record>
      <millis>1234894427018</millis>
      <sequence>54</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Starting applet
    </message>
    </record>
    <record>
      <sequence>55</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>56</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Applet started
    </message>
    </record>
    <record>
      <millis>1234894427019</millis>
      <sequence>57</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>basic: Told clients applet is started
    </message>
    </record>
    <record>
      <sequence>58</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar, version: null]
    </message>
    </record>
    <record>
      <sequence>59</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894427179</millis>
      <sequence>60</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894427180</millis>
      <sequence>61</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar : null
    </message>
    </record>
    <record>
      <sequence>62</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar
    </message>
    </record>
    <record>
      <millis>1234894427243</millis>
      <sequence>63</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/gluegen/webstart/gluegen-rt.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894427250</millis>
      <sequence>64</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/gluegen/webstart/gluegen-rt.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894427452</millis>
      <sequence>65</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/gluegen/webstart/gluegen-rt.jar : 304
    </message>
    </record>
    <record>
      <sequence>66</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/gluegen/webstart/gluegen-rt.jar : null
    </message>
    </record>
    <record>
      <sequence>67</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/gluegen/webstart/gluegen-rt.jar
    </message>
    </record>
    <record>
      <millis>1234894427528</millis>
      <sequence>68</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894427533</millis>
      <sequence>69</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894427540</millis>
      <sequence>70</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894427597</millis>
      <sequence>71</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894427598</millis>
      <sequence>72</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar : null
    </message>
    </record>
    <record>
      <sequence>73</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar
    </message>
    </record>
    <record>
      <millis>1234894427686</millis>
      <sequence>74</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894427693</millis>
      <sequence>75</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894427695</millis>
      <sequence>76</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894427751</millis>
      <sequence>77</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894427752</millis>
      <sequence>78</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar : null
    </message>
    </record>
    <record>
      <sequence>79</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar
    </message>
    </record>
    <record>
      <millis>1234894427901</millis>
      <sequence>80</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894427910</millis>
      <sequence>81</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894427912</millis>
      <sequence>82</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894427969</millis>
      <sequence>83</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar : 304
    </message>
    </record>
    <record>
      <sequence>84</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar : null
    </message>
    </record>
    <record>
      <sequence>85</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar
    </message>
    </record>
    <record>
      <date>2009-02-17T18:13:48</date>
      <millis>1234894428123</millis>
      <sequence>86</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428131</millis>
      <sequence>87</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428133</millis>
      <sequence>88</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428189</millis>
      <sequence>89</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894428190</millis>
      <sequence>90</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar : null
    </message>
    </record>
    <record>
      <sequence>91</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar
    </message>
    </record>
    <record>
      <millis>1234894428265</millis>
      <sequence>92</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428273</millis>
      <sequence>93</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428281</millis>
      <sequence>94</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894428321</millis>
      <sequence>95</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428378</millis>
      <sequence>96</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894428390</millis>
      <sequence>97</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar : null
    </message>
    </record>
    <record>
      <sequence>98</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar
    </message>
    </record>
    <record>
      <millis>1234894428488</millis>
      <sequence>99</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428500</millis>
      <sequence>100</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428502</millis>
      <sequence>101</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428559</millis>
      <sequence>102</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894428560</millis>
      <sequence>103</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar : null
    </message>
    </record>
    <record>
      <millis>1234894428561</millis>
      <sequence>104</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar
    </message>
    </record>
    <record>
      <millis>1234894428635</millis>
      <sequence>105</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428642</millis>
      <sequence>106</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428644</millis>
      <sequence>107</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428701</millis>
      <sequence>108</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar : 304
    </message>
    </record>
    <record>
      <sequence>109</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar : null
    </message>
    </record>
    <record>
      <sequence>110</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar
    </message>
    </record>
    <record>
      <millis>1234894428765</millis>
      <sequence>111</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428773</millis>
      <sequence>112</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428774</millis>
      <sequence>113</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428830</millis>
      <sequence>114</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar : 304
    </message>
    </record>
    <record>
      <sequence>115</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar : null
    </message>
    </record>
    <record>
      <millis>1234894428831</millis>
      <sequence>116</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar
    </message>
    </record>
    <record>
      <millis>1234894428883</millis>
      <sequence>117</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894428892</millis>
      <sequence>118</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894428894</millis>
      <sequence>119</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894428951</millis>
      <sequence>120</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894428952</millis>
      <sequence>121</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar : null
    </message>
    </record>
    <record>
      <sequence>122</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar
    </message>
    </record>
    <record>
      <millis>1234894428996</millis>
      <sequence>123</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar, version: null]
    </message>
    </record>
    <record>
      <date>2009-02-17T18:13:49</date>
      <millis>1234894429001</millis>
      <sequence>124</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894429007</millis>
      <sequence>125</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894429049</millis>
      <sequence>126</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894429104</millis>
      <sequence>127</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar : 304
    </message>
    </record>
    <record>
      <sequence>128</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar : null
    </message>
    </record>
    <record>
      <millis>1234894429105</millis>
      <sequence>129</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar
    </message>
    </record>
    <record>
      <millis>1234894429167</millis>
      <sequence>130</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894429174</millis>
      <sequence>131</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894429178</millis>
      <sequence>132</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <millis>1234894429234</millis>
      <sequence>133</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894429235</millis>
      <sequence>134</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar : null
    </message>
    </record>
    <record>
      <sequence>135</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar
    </message>
    </record>
    <record>
      <millis>1234894429263</millis>
      <sequence>136</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894429264</millis>
      <sequence>137</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894429269</millis>
      <sequence>138</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp, version: null]
    </message>
    </record>
    <record>
      <millis>1234894429275</millis>
      <sequence>139</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894429470</millis>
      <sequence>140</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp : 304
    </message>
    </record>
    <record>
      <sequence>141</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp : null
    </message>
    </record>
    <record>
      <millis>1234894429471</millis>
      <sequence>142</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp
    </message>
    </record>
    <record>
      <millis>1234894429565</millis>
      <sequence>143</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp, version: null]
    </message>
    </record>
    <record>
      <millis>1234894429573</millis>
      <sequence>144</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894429768</millis>
      <sequence>145</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp : 304
    </message>
    </record>
    <record>
      <millis>1234894429784</millis>
      <sequence>146</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp : null
    </message>
    </record>
    <record>
      <millis>1234894429785</millis>
      <sequence>147</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp
    </message>
    </record>
    <record>
      <millis>1234894429825</millis>
      <sequence>148</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894429831</millis>
      <sequence>149</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <date>2009-02-17T18:13:50</date>
      <millis>1234894430027</millis>
      <sequence>150</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894430028</millis>
      <sequence>151</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar : null
    </message>
    </record>
    <record>
      <millis>1234894430029</millis>
      <sequence>152</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar
    </message>
    </record>
    <record>
      <millis>1234894430069</millis>
      <sequence>153</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430084</millis>
      <sequence>154</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>155</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430136</millis>
      <sequence>156</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430138</millis>
      <sequence>157</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430143</millis>
      <sequence>158</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>159</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430154</millis>
      <sequence>160</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430156</millis>
      <sequence>161</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430168</millis>
      <sequence>162</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry found [url: https://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar, version: null]
    </message>
    </record>
    <record>
      <millis>1234894430175</millis>
      <sequence>163</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894430372</millis>
      <sequence>164</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: ResponseCode for https://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar : 304
    </message>
    </record>
    <record>
      <millis>1234894430462</millis>
      <sequence>165</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Encoding for https://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar : null
    </message>
    </record>
    <record>
      <sequence>166</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Disconnect connection to https://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar
    </message>
    </record>
    <record>
      <millis>1234894430466</millis>
      <sequence>167</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430506</millis>
      <sequence>168</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430507</millis>
      <sequence>169</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430513</millis>
      <sequence>170</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>171</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430520</millis>
      <sequence>172</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>173</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430521</millis>
      <sequence>174</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>175</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>176</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430527</millis>
      <sequence>177</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>178</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>179</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894430528</millis>
      <sequence>180</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>181</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>182</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>183</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Checking if certificate is in Deployment session certificate store
    </message>
    </record>
    <record>
      <date>2009-02-17T18:13:59</date>
      <millis>1234894439986</millis>
      <sequence>184</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: User has granted the priviledges to the code forever
    </message>
    </record>
    <record>
      <millis>1234894439999</millis>
      <sequence>185</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>186</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <date>2009-02-17T18:14:00</date>
      <millis>1234894440000</millis>
      <sequence>187</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Adding certificate in Deployment permanent certificate store
    </message>
    </record>
    <record>
      <sequence>188</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Removing certificate in Deployment permanent certificate store
    </message>
    </record>
    <record>
      <sequence>189</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Removed certificate in Deployment permanent certificate store as alias deploymentusercert$tsflag-1132515482805396946
    </message>
    </record>
    <record>
      <sequence>190</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Added certificate in Deployment permanent certificate store as alias deploymentusercert-4681638541804420869
    </message>
    </record>
    <record>
      <millis>1234894440001</millis>
      <sequence>191</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Saving Deployment certificates in C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
    </message>
    </record>
    <record>
      <sequence>192</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>security: Saved Deployment certificates in C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
    </message>
    </record>
    <record>
      <sequence>193</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>194</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440002</millis>
      <sequence>195</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>196</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>197</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440003</millis>
      <sequence>198</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>199</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>200</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>201</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440004</millis>
      <sequence>202</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>203</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>204</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>205</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440037</millis>
      <sequence>206</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440438</millis>
      <sequence>207</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>208</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440439</millis>
      <sequence>209</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>210</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>211</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440442</millis>
      <sequence>212</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440443</millis>
      <sequence>213</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>214</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>215</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440444</millis>
      <sequence>216</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>217</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440510</millis>
      <sequence>218</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440511</millis>
      <sequence>219</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>220</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>221</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>222</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440512</millis>
      <sequence>223</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>224</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440513</millis>
      <sequence>225</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>226</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>227</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>228</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440544</millis>
      <sequence>229</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>230</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>231</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440545</millis>
      <sequence>232</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>233</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>234</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>235</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440549</millis>
      <sequence>236</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>237</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440575</millis>
      <sequence>238</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440576</millis>
      <sequence>239</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440585</millis>
      <sequence>240</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>241</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>242</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440586</millis>
      <sequence>243</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>244</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>245</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440587</millis>
      <sequence>246</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>247</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>248</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>249</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440588</millis>
      <sequence>250</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440668</millis>
      <sequence>251</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440669</millis>
      <sequence>252</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>253</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440673</millis>
      <sequence>254</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440674</millis>
      <sequence>255</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>256</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>257</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>258</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440675</millis>
      <sequence>259</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>260</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440683</millis>
      <sequence>261</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894440684</millis>
      <sequence>262</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101\jln54102\jogl.dll
    </message>
    </record>
    <record>
      <date>2009-02-17T18:14:01</date>
      <millis>1234894441571</millis>
      <sequence>263</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441576</millis>
      <sequence>264</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441577</millis>
      <sequence>265</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>266</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>267</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>268</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441578</millis>
      <sequence>269</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>270</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>271</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>272</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441579</millis>
      <sequence>273</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441791</millis>
      <sequence>274</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441861</millis>
      <sequence>275</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441862</millis>
      <sequence>276</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101\jln54102\jogl_awt.dll
    </message>
    </record>
    <record>
      <millis>1234894441939</millis>
      <sequence>277</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/webservice/soap.php with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894441947</millis>
      <sequence>278</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>279</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894441987</millis>
      <sequence>280</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/webservice/soap.php with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <date>2009-02-17T18:14:02</date>
      <millis>1234894442210</millis>
      <sequence>281</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>282</sequence>
      <logger>sun.plugin</logger>
      <level>FINE</level>
      <class>com.sun.deploy.util.LoggerTraceListener</class>
      <method>print</method>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894442211</millis>
      <sequence>283</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>284</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>285</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894442508</millis>
      <sequence>286</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Cache entry not found [url: https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085, version: null]
    </message>
    </record>
    <record>
      <millis>1234894442517</millis>
      <sequence>287</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085 with proxy=DIRECT
    </message>
    </record>
    <record>
      <millis>1234894442519</millis>
      <sequence>288</sequence>
      <level>FINE</level>
      <thread>10</thread>
      <message>network: Connecting https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085 with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    </message>
    </record>
    <record>
      <date>2009-02-17T18:14:03</date>
      <millis>1234894443026</millis>
      <sequence>289</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443028</millis>
      <sequence>290</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443029</millis>
      <sequence>291</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>292</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>293</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>294</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443030</millis>
      <sequence>295</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>296</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>297</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>298</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443031</millis>
      <sequence>299</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443190</millis>
      <sequence>300</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>301</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443191</millis>
      <sequence>302</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>303</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443192</millis>
      <sequence>304</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>305</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>306</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443193</millis>
      <sequence>307</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>308</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <sequence>309</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    <record>
      <millis>1234894443194</millis>
      <sequence>310</sequence>
      <level>FINE</level>
      <thread>10</thread>
    </message>
    </record>
    Trace File
    Code:
    JNLPAppletLauncher: static initializer
    os.name = windows vista
    nativePrefix =   nativeSuffix = .dll
    Applet.init
    subapplet.classname = udesign.UDesignApplet
    subapplet.displayname = Shapeways Viewer Applet
    subapplet.image = https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg
    network: Cache entry not found [url: https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg, version: null]
    network: Connecting https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg with proxy=DIRECT
    network: Connecting https://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
    Applet.start
    os.arch = x86
    processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\jogl-natives-windows-i586.jar
    validateCertificates:
    VALIDATE: jogl.dll
    VALIDATE: jogl_awt.dll
    VALIDATE: jogl_cg.dll
    extractNativeLibs:
    EXTRACT: jogl.dll(jogl)
    EXTRACT: jogl_awt.dll(jogl_awt)
    EXTRACT: jogl_cg.dll(jogl_cg)
    processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\gluegen-rt-natives-windows-i586.jar
    VALIDATE: gluegen-rt.dll
    extractNativeLibs:
    EXTRACT: gluegen-rt.dll(gluegen-rt)
    Message: VERSION: 1.2.4
    ******** Creating mesh editor *
    JNLPAppletLauncher.loadLibrary("jogl")
    The selected editor is udesign.editor.mesh.MeshEditor[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    JNLPAppletLauncher.loadLibrary("jogl_awt")
    OpenGL details:
    Card vendor: ati technologies inc.
    Spec Version: 2.0.6479 Release
    Renderer: ATI Radeon Xpress 1250
    High-resolution shaders enabled
    network: Cache entry not found [url: https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085, version: null]
    network: Connecting https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085 with proxy=DIRECT
    network: Connecting https://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085 with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
  11. robert
    robert Member
    I have sent over to the development guys to take a look into it.
    Cheers!
    Robert
  12. minisumo
    minisumo Member
    Thanks guys!
    Just had a note from Arno, rechecked the 3D viewer and all is fine now!
    Sounds like a Vista 3D tools issue, sorted in a recent patch. Nice to see a company that doesn't forget it's users issues.
    :D
    best regards,
    Colin
