Home » Support » 3D Applications » Blender tutorial request
Blender tutorial request [message #2890] Sun, 08 February 2009 17:01 UTC Go to next message
avatar Anvariel  is currently offline Anvariel
Yes, I'm probably a real noob, but Blender has a HIGH learning threshold! I've tried to find a way to extrude things, but I just can't seem to make anything work! I think it would be great if there were a few tutorials on how to do this in Blender (and also in other 3D applications). The one on the site is too simple. Scaling the object down and using booleans can be VERY dangerous since scaling is not the same as "shrinking" from the surface. One could end up with unwanted holes, etc.
So, any skilled wonderful person who could present a nice little how-to list? Razz
Re: Blender tutorial request [message #2896 is a reply to message #2890 ] Sun, 08 February 2009 23:06 UTC Go to previous messageGo to next message
avatar loonsbury  is currently offline loonsbury
Hi Smile
Being a "Blender head", I understand the learning curve problem from personal experience. I recently found an effective solution to the hollowing problem, though: duplicate; never extrude. If you select the faces, duplicate them (SHIFT+D, 0, ENTER), then ALT+S to scale every face along its normal, you will usually end up with a close-to-perfect shrunken object. ALT+S even measures by units so instead of trying to get wallthickness by percentage you can just type in the mm representation.
You'll need to fix any faces that have scaled through other faces, I just merge the points together on the inside object so it doesn't get funky. Another possible problem is the inside/outside calculation for faces in Blender - sometimes unreliable. If your model is watertight before duplicating and comes out right already as an STL, make sure you flip normals of the new faces (W, 0).
The last part of this of course is connecting the inside and outside through a hole. Cut out the faces on both inside and outside in one spot, then connect the vertices (select 3-4 verts and press F).
I'd be happy to write the Blender tuts if no one else gets to it before I have time - I know I'm not the only proficient one.
Re: Blender tutorial request [message #2921 is a reply to message #2890 ] Mon, 09 February 2009 21:11 UTC Go to previous messageGo to next message
Thank you very much!! =) It helped me... to some extent anyway. I really don't like Blender to tell you the truth! There are some things that seem to be able only through hotkeys and this is usually unacceptable in user interface development. Anyway....
I tried the whole resizing along normals. Took me a while to figure out how to select the freaking polygons to begin with, but it finally worked. Unfortunately, the result is rather crap for my model. Around small parts (like the ears... it's a head I'm modelling) the resizing made vertices actually go through the outer surface. Kind of nasty. So I have to figure out some other way to tweek that. How I wish I had level sets now... *sigh* It would solve all my problems. Sad
Actually, thinking about a Blender tutorial now, I think it would be great to create a real "for total freaking newbies" blender tutorial. A lot of people use other kinds of software (like ZBrush, TopMod, etc.etc) and want to hollow out their objects in some free program. I think it would be supergreat if someone had the time to write down something like that.
Re: Blender tutorial request [message #3033 is a reply to message #2921 ] Thu, 19 February 2009 07:46 UTC Go to previous messageGo to next message
avatar daviesbobuk  is currently offline daviesbobuk
Glad I am not the only one having trouble with Blender.
In fact I need the Blender for Dummies course. I use Rhino 3D and have been exporting to STL and trying to upload, with limited success. When I load my 'failed' file into Blender and try to follow the Shapeways tutorial, I am completely lost.
BobD N-Train
Re: Blender tutorial request [message #3042 is a reply to message #2890 ] Fri, 20 February 2009 06:40 UTC Go to previous messageGo to next message
avatar qedqubit  is currently offline qedqubit
look for the precision modelling tutorial
it's a 160-page pdf document on how to model
bearings and screw thread and nuts
it's really a high quality tutorial on how to make really goodlooking design drawings with rendered sections & parts.
there are also a few handy keyboard command lists
<a href=" http://www.google.nl/search?hl=nl&rlz=1C1GGLS_nlNL292NL3 14&q=blender+keyboard+shorcuts&btnG=Zoeken&meta=" target="_blank"></a>
and i really recommend the greybeard tutorials
goodluck!
[Updated on: Fri, 20 February 2009 06:41 UTC]
Re: Blender tutorial request [message #15806 is a reply to message #2921 ] Sun, 08 August 2010 17:49 UTC Go to previous messageGo to next message
avatar Rybec  is currently offline Rybec
Yes, there are a number of things in Blender that are only accessible through hotkeys and many other things that are very difficult to find in the UI. Blender was not designed to be easy to use out-of-the-box (the assumption that visual UIs have to be all inclusive is based on the idea that all applications should be easy to learn without reading the documentation). It was designed to be very fast to use once you learn to use it (and this is optimized for animation). (The focus is not on a good visual UI, it is on creating things at very high speeds. When speed is the primary issue, good visual UIs just get in the way, and extensive hotkeying is essential.)
I have been learning to use Blender for years (off and on) and only very recently have I gotten good enough to use it effectively. Now that I have had the time to actually learn to use Blender, I can tell you that it is very fast to use once you learn the hotkeys. (Note that the primary reason I am decent at Blender now is that using Shapeways and the Shapeways Blender tutorials has given me enough knowledge to know what to look for when searching for more information.)
The problem right now is that most Blender tutorials focus on animation, but most beginners do not even know how to make still models with it. So we really need more still modeling tutorials.
I guess reading the documentation would help also (I have not done this yet, but I am certain it would help.)
[Updated on: Sun, 08 August 2010 17:51 UTC]
Re: Blender tutorial request [message #15823 is a reply to message #2890 ] Mon, 09 August 2010 13:17 UTC Go to previous messageGo to next message
I downloaded the blender basics pdf to my iphone to read on my down time... So I'll be done reading it after I retire lol. It's just so different then any CAD package I've used before. In many good ways, but the interface is whats catching me.
Re: Blender tutorial request [message #15825 is a reply to message #15823 ] Mon, 09 August 2010 13:33 UTC Go to previous messageGo to next message
Hi there!
I've recently learned how to use Blender as well.
I found this "Noob to pro" wiki rather helpful when learning how to model basic shapes and more advanced stuff too:
Blender 3D: Noob to Pro
It also contains a "Hotkeys" section for the various modes.
("edit mode" and "object mode" are probably the only modes you need for Shapeways-type modeling);
Blender 3D: Noob to Pro/Hotkeys
This tutorial taught me how to set up Blender the way I like it (top/front/side/3D view in 4 separate "panes" and the tabs/buttons below):
A detailed overview of the Blender Interface
I hope that helps...
Just be patient and try to get the hotkeys to stick in your memory. Very Happy
Re: Blender tutorial request [message #15938 is a reply to message #2890 ] Wed, 11 August 2010 19:15 UTC Go to previous messageGo to next message
avatar stuartar  is currently offline stuartar
This helped me get my head around Blender,
http://www.rab3d.com/tutorial.html
Re: Blender tutorial request [message #15942 is a reply to message #15938 ] Wed, 11 August 2010 20:20 UTC Go to previous messageGo to next message
I downloaded the pdf for this tutorial and it has taught me a whole bunch of new stuff that I did not know before. If you have a good memory (it goes step by step at first, but after a while it assumes that you remember the steps to do things), it will really get you started on fast modeling. Of course, it does not focus on organic modeling, mostly just geometric modeling, but it will help regardless of what you intend on making.
Re: Blender tutorial request [message #16117 is a reply to message #2890 ] Sun, 15 August 2010 17:52 UTC Go to previous messageGo to next message
avatar dskloet  is currently offline dskloet
I found this 40 minute video introduction very helpful:
http://www.cartoonsmart.com/free_blender_tutorial1.php5
Then same guy also has a youtube channel with short videos about how to do specific tasks:
http://www.youtube.com/bitsofblender
Re: Blender tutorial request [message #16125 is a reply to message #16117 ] Sun, 15 August 2010 19:22 UTC Go to previous messageGo to next message
I posted this on BlenderNation earlier today:
http://www.blendernation.com/blender-video-tutorials-galore/
Almost 100 video tutorials for beginners. Enjoy! <evil grin>
Re: Blender tutorial request [message #16285 is a reply to message #16125 ] Tue, 17 August 2010 19:15 UTC Go to previous messageGo to next message
Nice, thanks. My final goal with Blender is to make 3D movies. While Shapeways has done a lot to improve my modeling skills, I needed something like this to get me up to animation.
Re: Blender tutorial request [message #17431 is a reply to message #2890 ] Wed, 08 September 2010 16:40 UTC Go to previous message
ah actually this is the tutorial i meant:
http://www.blendernation.com/2009/05/01/the-process-of-model ling-and-rigging-a-mechanical-model/
which is of the same author as the ball bearing tech modeling tutorial:
http://www.blendernation.com/2007/12/27/precision-modelling- pdf-guide/
better late than never !
Previous Topic:meshlab question
Next Topic:Exporting issues...
