I am doing my first project on Cinema 4D R10.
It is very simple. A cylinder (2mm thick, 25 mm Diameter), some text curved into circles on both sides (0,5mm thick), and some shapes on both sides (0,5mm thick)
I understood, from the support section, that I have to NOT use Booleans.
I also understood that I have to create a single object (in that I may be wrong).
So how do I connect my central cylinder to the texts ans shapes without the boolean to create a single object ?
I really don't know how to create a clean object without this boolean. I don't understand why it wouldn't work. Usually, after the model is shaped into one object, I "convert it to object Polygone" then clean it if necessary. The "not using Boolean" just messes with my way of doing things !
Thanks for your answers !
Stéphane
