Home » Support » 3D Design » Newbie help
Newbie help [message #31586] Tue, 26 July 2011 19:18 UTC Go to next message
avatar Camazine  is currently offline Camazine
I have just created a model using TopMod, and exported it as an .stl file (www.shapeways.com/model/301956/). How do I specify a particular size for the model. The design now appears to be 0.7 cm. I would like to make it larger.
Re: Newbie help [message #31592 is a reply to message #31586 ] Tue, 26 July 2011 20:21 UTC Go to previous messageGo to next message
You will need to scale the object to the correct size, prior to upload.
I'm not familiar with Topmod, but I imagine it has some scaling capabilities?
[Updated on: Tue, 26 July 2011 20:21 UTC]
Re: Newbie help [message #31595 is a reply to message #31592 ] Tue, 26 July 2011 20:30 UTC Go to previous messageGo to next message
Actually, TopMod doesn't seem to have scaling abilities. How about meshlab? Is there a way to scale an object within that program? I could import my TopMod models and work from there. I looked briefly at Meshlab, but didn't see a menu item there for scaling an object.
Re: Newbie help [message #31605 is a reply to message #31595 ] Tue, 26 July 2011 21:04 UTC Go to previous message
It's "hidden" under "normals, curvature, orientation" -> "apply transform"
Previous Topic:Model not available in Polished WSF?
Next Topic:Error messages uploading a model
