| Re: Resizing product [message #31577 is a reply to message #31576 ] Tue, 26 July 2011 17:47 UTC |
Hi Jules,
I am not sure I understand correctly, but you uploaded the model as an STL with the "mm" unit selected for the first?
And used a different scale for the second?
If you use STL files for upload, the selection box decides what the native STL unit will be for real.
So if you model is 25.4 units long and you select mm on upload it will be 25.4 mm = 2.54 cm = 1inch.
Sometimes matters become more complicated when the used 3d software uses an own internal unit and converts things on save.
Can you give some more info?
Love your (power) Julia bulbs!
Tried those myself, but never had much luck in generating affordable and printed pieces from it.
Stijn
| Re: Resizing product [message #31579 is a reply to message #31577 ] Tue, 26 July 2011 17:57 UTC |
Your interpretation is correct, but that was not the question.
I want to know what is the meeasure of the origal stl file and how I have to resize it to level that the printed output is 1 inch ^3
| Re: Resizing product [message #31588 is a reply to message #31582 ] Tue, 26 July 2011 19:46 UTC |
Dag Stijn,
Ik heb bij het laden van een stl file slechts 3 mogelijkheden voor het kiezen van de dimensie: mm., inch en meter. Dat is 1 mm., 25 mm. of 1000 mm. Wat ik nu vraag is om een meer variabele schaal, zodat ik de grootte van het te printen product precies kan bepalen.
Maar misschien is dit wel in de downloadprocedure opgenomen, maar mis ik deze parameter.
| Re: Resizing product [message #31601 is a reply to message #31590 ] Tue, 26 July 2011 20:57 UTC |
Dit is wel wat ik bedoel. Ik ga eens kijken bij het gratis meshlab. Waar kan ik dat vinden?
| Re: Resizing product [message #31612 is a reply to message #31603 ] Tue, 26 July 2011 21:42 UTC |
Ik heb de software gevonden. Dank.
De factor moet zijn: 2,54/0.3 ~ 8.5
Ik ga het proberen.
| Re: Resizing product [message #31926 is a reply to message #31612 ] Mon, 01 August 2011 16:20 UTC |
for the reference of those (unfortunate) English only speakers, gentlemen.
Could you please inform us as to how this issue was resolved?
Thank you very much!
Thanks for listening,
-Lefty
www.shapeways.com/shops/lefty
| Re: Resizing product [message #31927 is a reply to message #31926 ] Mon, 01 August 2011 16:55 UTC |
In short, Jules was asking how to variably resize the model on upload.
But that is not yet possible on the site, so has to be done pre-upload.
I recommended Meshlab for this.
As I also did in this English thread here :
http://www.shapeways.com/forum/index.php?t=msg&goto=3160 5&#msg_31605
[Updated on: Mon, 01 August 2011 16:56 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
| Re: Resizing product [message #31932 is a reply to message #31927 ] Mon, 01 August 2011 19:18 UTC |
Much appreciated, sir!
-Lefty
