Home » Support » 3D Applications » Sketchup design size problems
Sketchup design size problems [message #31019] Sun, 17 July 2011 13:08 UTC Go to next message
avatar Asphalt  is currently offline Asphalt
Hi Everyone,
I created my first designs yesterday using Sketchup. I converted them and repaired them with little issue once I downloaded the recommended software. My problem is that they kept being rejected for being too small. Originally my designs were roughly 1.5cmX1.5cmX5CM in size. I know there are many things much smaller than this available on Shapeways. I had to keep scaling them up until they were closer to 3X3X8cm before they were accepted. Can anyone give me any advice on how to make small pieces using sketchup? Thank you in advance.
Sean
Re: Sketchup design size problems [message #31042 is a reply to message #31019 ] Mon, 18 July 2011 00:35 UTC Go to previous message
Hi Sean, welcome to Shapeways Smile
It sounds like you may be having issues with units...hard to say with limited info. What file format are you uploading in?
If the Sketchup file isn't proprietary, you can PM it to me and I'll take a look.
-Marcus
Previous Topic:Unbiased rendering
Next Topic:Export to STL from within Sketchup
