I've been designing a camera bracket for the last few months, tweaking the design and dimensions by getting prototypes done in Black, Strong, and Flexible. Once I was happy with it, I ordered a test print in stainless steel. Unfortunately (and as some of you know), the stainless steel process is a thoroughly different beast. The model warped when it was fired and melted in some parts. Even if it had been pristine, however, stainless steel is bloody difficult to work with, and I needed to be able to tap the finished piece to add threads. If only I could have the reliability of WSF with the durability of steel.
I came across a firm in Maryland called
RePliForm that specializes in nickel-coating 3D printed parts and models. I sent them one of my bracket prototypes for a sample coating late last week and received it back today.
I'm impressed. The coating is thin enough to leave details and surface qualities in the model, but strong enough to protect the part itself from wear or torque. Because it was just a sample coating, there's no polishing or extra processing, but the results are fantastic nonetheless. Below you can see an uncoated prototype (in BSF), the nickel-coated model next to it, and the test stainless steel print.
