| Re: FUD wax removal. FUD plastic [message #47052 is a reply to message #46231 ] Mon, 16 April 2012 07:42 UTC |
This weekend I went out in search for Bestine on the recommendation of FrankNscale.
While I didn't find Bestine, I browsed the cleaners and spotted Goo Gone and De-Solv-It Citrus.
De-Solve-It was more expensive (~9 bucks), but the label says it specifically removes wax, among others. As I was on a budget I saved this product for my next go.
Goo Gone was 3 bucks, so I picked one up.
The process took just minutes and resulted in perfectly clean, wax free model (with no discoloration/whitening), ready for paint. I'm surprised that Goo Gone has not been discussed before.
1. Rinse and brush away any large blobs of wax.
2. Using a toothbrush that has been sitting in hot water (which softens it's bristles), dip the brush and FUD part in Goo Gone and lightly scrub all surfaces 2-3 times. Rinse/swash the brush every so often to remove the removed wax so you don't just spread it around. Re-dip the brush in Goo Gone and continue.
3.Quickly rinse and brush again in warm-soapy water.
Done.
| Re: FUD wax removal. FUD plastic [message #47055 is a reply to message #47052 ] Mon, 16 April 2012 07:56 UTC |
Sounds like good stuff, which variety of Goo Gone did you use? Have you tried painting cleaned parts yet?
| Re: FUD wax removal. FUD plastic [message #47056 is a reply to message #47055 ] Mon, 16 April 2012 08:01 UTC |
I'm not aware of different varieties of Goo Gone, but my bottle says Citrus Power.
Here's a painted (no primer), Goo Gone cleaned, model.
(Black is Polly Scale Acrylic, Red and Yellow is Testors Enamel)
| Re: FUD wax removal. FUD plastic [message #47151 is a reply to message #47056 ] Wed, 18 April 2012 13:01 UTC |
Goo Gone sounds interesting. Is there any particular brand of soap used to final cleaning?
I was thinking of the post that mentions soap can contain Lanolin which can have effects on the FUD.
Bob
| Re: FUD wax removal. FUD plastic [message #47157 is a reply to message #47151 ] Wed, 18 April 2012 14:01 UTC |
Lanolin should have no effect on FUD at all, though it may prevent paint adhering properly.
Bill Bedford
| Re: FUD wax removal. [message #48181 is a reply to message #28535 ] Thu, 10 May 2012 09:57 UTC |
I have a suggestion that might work well to break up chunky bits on some pieces: Dental floss. I was about to consider using some on my pendants when I realised it could be used on models like the mini rubiks cube.
Enjoys spending 98 hours a week learning, making and designing stuff. The picture of me as a kid is... pretty much what you're dealing with.
| Re: FUD wax removal. [message #49287 is a reply to message #48181 ] Fri, 01 June 2012 16:11 UTC |
I expecting a FUD part pretty soon that consists of a grid with 0,4mm thickness and 8mm between the sections, first this model was rejected due to that it probably would warp at cleaning, but I might get it anyway since I would take the risk of warping and I was wondering what's the best way to clean such a structure, I have read this entire thread and there's many options to choose from but since my model is an open grid i guess leaving it in a hot space would cause the wax to melt and escape the grid, but I haven't ordered any FUD before so maybe it's not as easy as i imagine?
| Re: FUD wax removal. [message #49301 is a reply to message #49287 ] Fri, 01 June 2012 18:05 UTC |
If you live in the US and have a Michael's Hobby store nearby, Bestine is great for cleaning FUD
| Re: FUD wax removal. [message #49302 is a reply to message #49301 ] Fri, 01 June 2012 18:33 UTC |
| stonysmith wrote on Fri, 01 June 2012 18:05 | If you live in the US and have a Michael's Hobby store nearby, Bestine is great for cleaning FUD
I'm in Denmark :S I haven't heard about Bestine, but what's the ingredients? Maybe they something similar here, but I think the biggest challenge is that I'll have 1 try only for this so the method needs to really work the first time.
| Re: FUD wax removal. [message #49337 is a reply to message #49336 ] Sat, 02 June 2012 19:20 UTC |
| stop4stuff wrote on Sat, 02 June 2012 19:14 | This link will help for info about Bestine.
Thank you for the hint!
I have searched for Bestine and can see it's not really available to me over here. But is the product so good that I should order something or, based on my explanation, would other methods be just as good for removing wax from such a grid structure?
| Re: FUD wax removal. [message #49340 is a reply to message #49337 ] Sat, 02 June 2012 19:42 UTC |
try this link
Although, I've not tried it myself ithers have had good results with the product. I'm waiting on a delivery for some FUD prints (~11th) and will be using an ultrasonic cleaner.
| Re: FUD wax removal. [message #49341 is a reply to message #49337 ] Sat, 02 June 2012 19:42 UTC |
I use 90% isopropyl alcohol because, frankly, I don't like the idea of washing my models in gasoline.
Earl Grey, hot.
| Re: FUD wax removal. [message #50661 is a reply to message #28535 ] Sun, 01 July 2012 05:15 UTC |
I've read through most of those, and tried most. I have not read through all of these suggestions so maybe this method has already been mentioned.
I have minor success with chemicals because of the nature of my model,
Finally I took the figure and placed it on a couple of paper napkins and went over it with a hair dryer. You don't have to get it too hot for the wax to start flowing, just move the hair dryer over the piece back and forth and in no time the wax perculates out of the holes in the model.
Then clean off the residue which has deposited itself on the outer surface with the solvent of your choice and a cloth applicator that sheds no lent.
I use an old piece of linen cut up.
I found it also helps to clamp the napkins down to keep them from getting blown all around by the hair dryer.
Sorry if this method has already been mentioned.
This is a transparent view of the figure to give you some idea of the amount of wax I am talking about.
This particular figue has 2 holes. One 2 mm hole at the top of the head and one 1 mm hole at the bottom of the torso.
[Updated on: Sun, 01 July 2012 05:22 UTC]
| Re: FUD wax removal. [message #52252 is a reply to message #49301 ] Fri, 03 August 2012 05:14 UTC |
[Updated on: Fri, 03 August 2012 05:17 UTC]
| Re: FUD wax removal. [message #54929 is a reply to message #50661 ] Fri, 05 October 2012 11:42 UTC |
Just to share one more war story:
I have a model with mm scale encapsulated channels. I have had good success with the following method:
1) Heat the model up to 60°C to melt the wax.
2) Pressurize the channels with a syringe to push out the molten wax.
3) Push through toluene (a standard organic solvent), to clean away any wax residues.
The toluene doesn't seem to dissolve or discolor the plastic. I haven't tried painting the models, but I assume it works after the toluene has dried.
Just be sure to use adequate ventilation and be aware of the fire hazard when working with toluene (as always consult the Material Safety Data Sheet for any new materials, for example here:
KBG
| Re: FUD wax removal. [message #54943 is a reply to message #54929 ] Fri, 05 October 2012 17:50 UTC |
| kristgy wrote on Fri, 05 October 2012 11:42 | 3) Push through toluene (a standard organic solvent), to clean away any wax residues.
Have you tried Heptane? There's a product called Bestine available from hobby stores such as Michaels. It has worked very well for me cutting the wax.
| Re: FUD wax removal. [message #55034 is a reply to message #55031 ] Mon, 08 October 2012 15:10 UTC |
Thanks, for the suggestions on heptane. I am in Sweden, so I am not sure I will find Bestine in stores here, but I will try to see if I can get hold of heptane in another form. It is of course preferable to use the least nasty chemical that will do the job.
I am working in a fumehood with the toluene, and that is definitely advisable.
KBG
| Re: FUD wax removal. [message #57942 is a reply to message #33808 ] Tue, 04 December 2012 06:12 UTC |
so you can or cant use acetone?
mine had some kind of crystalization on it still trying to figure out how to get that off any ideas?
| Re: FUD wax removal. [message #57962 is a reply to message #28535 ] Tue, 04 December 2012 16:35 UTC |
My recent FUD deliveries no longer have the hard wax to remove, instead there
is an oily sludge deposit that flushes easily with a hot water jet and w/up liquid.
Post-production, I think Shapeways must sometimes use a solvent to either
chip-out items or check detail is present on very small items.
[Updated on: Tue, 04 December 2012 16:38 UTC]
| Re: FUD wax removal. [message #57967 is a reply to message #57962 ] Tue, 04 December 2012 17:54 UTC |
| Phxman wrote on Tue, 04 December 2012 16:35 | My recent FUD deliveries no longer have the hard wax to remove, instead there
Same here. I just soak my parts in isopropyl alcohol for a few minutes and its a perfect surface to paint.
My last three orders have been excellent and I'm considering making my parts public again.
| Re: FUD wax removal. [message #67125 is a reply to message #57967 ] Tue, 30 April 2013 09:39 UTC |
i have found a very simple way for wax removal: compressed air.
i washed my last FUD-prints with some "nail polish remover" (without acetone) and then literally blown away the liquid with compresed air.
That works for me better than anything i tried before!
