Hello!
This is the original message I received after my order was processed then canceled:
"You've sold models that unfortunately can't be produced. Our apologies for the fact that our validation software did not catch this earlier.
The following models have been rejected:
- Final 2: Other (do not use) : remaining shell
https://www.shapeways.com/model/260228/final_2.html
- Shapeways Image Popper: Other (do not use) : remaining shell
https://www.shapeways.com/model/260233/shapeways_image_popper .html"
I uploaded a black and white image carefully following the guidelines for the Shapeways Image Popper software.
I guessed that the green part was where problem was. I do not have the experience of 3-D modeling nor my own software to make changes.
This is my first time printing a 3D model and I was just trying to create a test. Customer service responded and said that I have a "loose shell" and suggested that I could remove that aspect. I have searched the forums and can't really find an answer to the "loose shell" problem. What does loose shell mean?
Without removing the green line entirely, how can I fix this problem with my limited resources? How can I fix this model using the shapeways image popper?
Would it help if I kept a larger border/ base around the edges?
Thank you kindly for your time,
