Home » Community » It arrived! » Geared D6
Geared D6 [message #27940] Fri, 20 May 2011 20:06 UTC Go to next message
Shapeways Crew
The Geared D6 did finally arrive! It is in Frosted Ultra Detail.
/openfile/249527/photos/photo40894.jpg
/openfile/249527/photos/photo40892.jpg
/openfile/249527/photos/photo40895.jpg
Even if it is not fully functional, I am very happy with the result: none of the gears get fused although the very small clearances.
Nevertheless the gears of the number 6 are not turning at all. But except 6, all the gears of the other faces are turning a little bit when you turn the big gear of face number 1.
Unfortunately I don't know really what to do. I have the feeling that this is due to too much clearance on the axes, but it is perhaps just that the movement cannot be transmitted through so many gears: from 1 to 3 and from 3 to 6.
I will probably try to reduce some clearances and to have less teeth in the internal gears (compared to the external) and hope this will be enough to fix the issue.
I will post a video soon.
Re: Geared D6 [message #27942 is a reply to message #27940 ] Fri, 20 May 2011 21:00 UTC Go to previous messageGo to next message
Wow, that's amazing!
Is all of the wax support material out? - it will bind things up a bit. And a spray of silicone/ptfe oil might help things too.
Re: Geared D6 [message #27945 is a reply to message #27942 ] Fri, 20 May 2011 21:19 UTC Go to previous messageGo to next message
Shapeways Crew
Thanks Stop4stuff. When you see how close the teeth of the different gears are, you just cannot believe it!
Yes, I think there was no more wax inside (I put it in hot water with soap to try to remove any wax, but according to me, this had no effect, it was already clean).
I should try to lubrificate it, you are right. I did not even think about that...
Re: Geared D6 [message #27950 is a reply to message #27940 ] Fri, 20 May 2011 22:16 UTC Go to previous messageGo to next message
Very cool !!
Is FUD strong?
http://www.3Dizingof.com
Re: Geared D6 [message #27951 is a reply to message #27950 ] Fri, 20 May 2011 22:57 UTC Go to previous messageGo to next message
avatar WillLaPuerta  is currently offline WillLaPuerta
Awesome! This really is the die I've always wanted to make . . . now what do I have to look forward to?
[Updated on: Fri, 20 May 2011 23:00 UTC]
"I am just a humble servant with a message here for you" Reaper Media on Facebook
Re: Geared D6 [message #27964 is a reply to message #27951 ] Sat, 21 May 2011 07:46 UTC Go to previous messageGo to next message
Shapeways Crew
@Dizingof: Yes, I would say it is quite strong. The gears have a thickness of 1 mm but the teeth are quite small. And although I tried to force to make them turn, none of the teeth broke.
@WillLaPuerta: Thanks. This opens a lot of new possibilities... I am sure you will find something Wink
Re: Geared D6 [message #28125 is a reply to message #27964 ] Tue, 24 May 2011 20:21 UTC Go to previous messageGo to next message
Shapeways Crew
The video of this first prototype is now available.
As you can see all the gears can move (I mean: none is fused), but the gears of the face number six cannot turn by moving the gear of face number one.
It seems that the axes of the middle gears of face number 3 and 5 are moving a lot: probably to much clearance there...
Re: Geared D6 [message #28127 is a reply to message #28125 ] Tue, 24 May 2011 20:47 UTC Go to previous messageGo to next message
avatar KBscale  is currently offline KBscale
Can you post a drawing to show how the gears are arranged on the inside?
Re: Geared D6 [message #28128 is a reply to message #28125 ] Tue, 24 May 2011 20:51 UTC Go to previous messageGo to next message
That's awfully good Magic.
From the video, it looks like there's quite a bit of slop in the gears & axles, what kind of clearances did you use?
Re: Geared D6 [message #28132 is a reply to message #27940 ] Tue, 24 May 2011 21:26 UTC Go to previous messageGo to next message
Sweet !
I think i'm going to like this cool material - thanks Magic
Re: Geared D6 [message #28134 is a reply to message #28132 ] Tue, 24 May 2011 21:47 UTC Go to previous messageGo to next message
Shapeways Crew
Thank you all.
@KBscale: Have a look at this post. Number three is transmitting the movement from one to six. It should answer your questions. If not, let me know...
@Stop4stuff: The clearances between the teeth are very small (0.1 or 0.05mm). Instead, for the axle, the clearances are +/-0.25mm in all directions that is 0.5 mm in x, y and z direction (the be clearer: 0.25 mm for the radius = 0.5 mm for the diameter). That's far too much. But I was so afraid to have the different parts fused... I think I will try +/-0.1 mm in all directions.
@Dizingof: Yes, this material is not perfect, but very very promising... The main advantages are the small wall thikness and the ridiculously small minimal clearances...
[Updated on: Tue, 24 May 2011 21:51 UTC]
Re: Geared D6 [message #28136 is a reply to message #28134 ] Tue, 24 May 2011 22:14 UTC Go to previous messageGo to next message
With a solid 0.1mm clearance, you may get wax left in, seizing things up like with my little rubiks cubes... as yet, I've not found a workable solution to free them up without damaging them (#9 & #8 I used hot water & detergent, both broke, #7 spent 4 days in mineral/white spirits - one part was still siezed and the central spindle had gone soft, #6 is soaking in a thin penetrating oil right now, still 5 more to go)
Maybe your option could be like one of the examples here somewhere for WSF where there are nodules sticking out of the main shaft with very small clearance (I'll post the link to the page when I can find it)
Re: Geared D6 [message #28137 is a reply to message #28136 ] Tue, 24 May 2011 22:18 UTC Go to previous messageGo to next message
stop4stuff wrote on Tue, 24 May 2011 22:14
Would an air pressure nozzle that you can find in any gas station do the trick? to clear the tiniest wax residue
Re: Geared D6 [message #28138 is a reply to message #28137 ] Tue, 24 May 2011 22:26 UTC Go to previous messageGo to next message
It might do, but with 2mm parts stuck together with 0.1mm of wax making up a 6.2mm cube, I've got a fair to middling chance of watching the cube disintigrate into itty bitty bits of plastic shrapnel with the one in the filling station... I have a LEGO air compressor I built that may do the job and is certainly worth a try... thanks for the idea Smile
Re: Geared D6 [message #28142 is a reply to message #28136 ] Wed, 25 May 2011 02:24 UTC Go to previous messageGo to next message
Do you mean the Woosh machine article?
Re: Geared D6 [message #28149 is a reply to message #28136 ] Wed, 25 May 2011 04:30 UTC Go to previous messageGo to next message
You could try an ultrasonic cleaner. Sometimes you can find small low-cost units designed for cleaning jewellry etc.
Re: Geared D6 [message #28153 is a reply to message #28136 ] Wed, 25 May 2011 06:14 UTC Go to previous messageGo to next message
Shapeways Crew
@Stop4stuff: There are some interesting techniques to have small clearances without the need of large areas facing with small void space between them.
Like this: http://www.shapeways.com/forum/index.php?t=msg&&th=5 145&goto=26920#msg_26920
I could not found the one you are mentionning, but I remember it. It is basically the same idea: not having the same diameter on all the length of the axle.
I am unsure this can apply to such small parts. Perhaps just adding some holes where the wax could get trapped (under the gears for example)...
Re: Geared D6 [message #28155 is a reply to message #28142 ] Wed, 25 May 2011 06:31 UTC Go to previous messageGo to next message
stannum wrote on Wed, 25 May 2011 02:24
Yep, that's the one, and @Magic, yep same idea there too.
@KBscale, thanks for the idea, I know one or two poeple that might just have one Smile
Re: Geared D6 [message #28316 is a reply to message #28155 ] Sun, 29 May 2011 07:55 UTC Go to previous messageGo to next message
Shapeways Crew
I found a flaw in the design that probably explains why the gears are not turning properly.
So... back to the drawing board... Smile
Re: Geared D6 [message #43101 is a reply to message #27940 ] Mon, 30 January 2012 11:39 UTC Go to previous message
avatar maximus123  is currently offline maximus123
nahicee.........
Previous Topic:1st model arrived :)
Next Topic:Metal Skull Die by Artfulshrapnel
