Home » Community » It arrived! » Menger FUD
Menger FUD [message #27603] Mon, 16 May 2011 16:05 UTC Go to next message
After ( or rather during ;-P) the FUD announcement my inspiration lacked a little, so I quickly made these and got them a few days back:
index.php?t=getfile&id=8874&private=0
Three sizes 1, 1.5 and 2 cm, on a 10ct, 20ct and 50ct Euro coin respectively.
As the holes are really tiny, there was a lot of support material still on and in them. A kind of oily greasy substance.
It gave them quite a yellow tint.
And at first it looked like not all holes made it through (pun intended)
As the safety datasheet for this material looks scary, I decided to wash them thoroughly first Smile
I used hot tap water (60C) and some dish soap. Soaked and shaked them a while and rinsed abundantly.
After drying is turns out FUD is Fudtastic Very Happy
All the holes are there!
Big one (2.0cm) Smallest holes 0.74 mm :
index.php?t=getfile&id=8875&private=0
Middle one (1.5cm) Smallest holes 0.55 mm :
index.php?t=getfile&id=8876&private=0
Smallest one (1 cm) Smallest holes 0.37 :
index.php?t=getfile&id=8877&private=0
The camera (and view angle) does not pick up these tiny objects, but on visual inspection, ALL holes are through and through!
In all dimensions, FUD is unbelievable!
At this rate a Level 5 is possible! Who will be first ? Wink
Virtox
[Updated on: Mon, 16 May 2011 16:29 UTC]
Re: Menger FUD [message #27606 is a reply to message #27603 ] Mon, 16 May 2011 16:33 UTC Go to previous messageGo to next message
avatar Eeppium  is currently offline Eeppium
Holy cubes eh Razz
What´s the wall thickness on those, looks like it´s very near the limits of the material.
Re: Menger FUD [message #27607 is a reply to message #27606 ] Mon, 16 May 2011 16:36 UTC Go to previous messageGo to next message
Yep, wall thickness is the same as the hole size, so 0.37 0.55 and 0.74 mm
Re: Menger FUD [message #27609 is a reply to message #27607 ] Mon, 16 May 2011 16:49 UTC Go to previous messageGo to next message
Awesome stuff virtox!
0.3mm wall thickness is do-able Wink
Re: Menger FUD [message #27615 is a reply to message #27609 ] Mon, 16 May 2011 17:27 UTC Go to previous messageGo to next message
Well to be honest, I did not think the 0.37 mm FUD would be a DUD, but I'm pleasantly surprised Wink
[Updated on: Mon, 16 May 2011 17:28 UTC]
Re: Menger FUD [message #27617 is a reply to message #27603 ] Mon, 16 May 2011 18:21 UTC Go to previous message
avatar jasolo  is currently offline jasolo
I had a similar idea: my 4-level Menger cube with 0.3mm holes (2.4cm) has been shipped today, so I'll post photos soon.
I think level-4 it's the maximum level printable for Menger cube, because level-5 must be around 10 millions of triangles.
Previous Topic:Twisted Starminx
Next Topic:FUD - Shoe and Frame
