Hand-Crank Fan
Hand-Crank Fan [message #26885] Tue, 03 May 2011 04:35 UTC Go to next message
avatar vertigopolka  is currently offline vertigopolka
I just received a print of my "Hand-Crank Fan" model in WSF.
This model is a single print with six moving parts, and is specifically designed for the loose tolerances of Shapeways' WSF material. The entire model is printed with all of the parts in position; nothing is assembled post-production.
The 1:9 gear ratio (made from two sets of gears each with a 1:3 gear ratio) makes the fan blades rotate nine times for every single rotation of the crank. The grip of the crank handle freely rotates as well.
Based on this latest print, I will be making a some minor adjustments before releasing the model for sale.
Hand-Crank Fan in action (video): Hand-Crank Fan video
Model page: Hand-Crank Fan model
index.php?t=getfile&id=8666&private=0
index.php?t=getfile&id=8667&private=0
index.php?t=getfile&id=8668&private=0
index.php?t=getfile&id=8669&private=0
@vertigopolka
http://www.vertigopolka.com
Re: Hand-Crank Fan [message #26888 is a reply to message #26885 ] Tue, 03 May 2011 06:34 UTC Go to previous messageGo to next message
Shapeways Crew
Wow... Very interesting and very elegant! I notice that the gears have very pointy teeth. Is is a way to deal with the loose tolerances of WSF?
Re: Hand-Crank Fan [message #26889 is a reply to message #26888 ] Tue, 03 May 2011 06:52 UTC Go to previous messageGo to next message
@Magic: Thanks! Yes, I found that because of the tolerances, I needed to put an extended, rounded tip on the teeth in order for them to mesh correctly. Otherwise, they would slip by each other. The tips on the gears help to nudge the other gears around just enough to keep everything turning very smoothly.
@vertigopolka
Re: Hand-Crank Fan [message #26890 is a reply to message #26889 ] Tue, 03 May 2011 06:54 UTC Go to previous messageGo to next message
Looks like quite a feat of (3d printed) engineering.
When do we get a video of it in action? Very Happy
Edited: Note to self -- look closer...
[Updated on: Tue, 03 May 2011 07:07 UTC]
Community Manager | Shapeways
Re: Hand-Crank Fan [message #26891 is a reply to message #26890 ] Tue, 03 May 2011 07:16 UTC Go to previous messageGo to next message
@ana: I put the link to the video in the original post (I don't know how to embed video in the forums).
Oops, just noticed your "note to self," but here's the link again :): Hand-Crank Fan video
@vertigopolka
Re: Hand-Crank Fan [message #26892 is a reply to message #26890 ] Tue, 03 May 2011 07:16 UTC Go to previous messageGo to next message
Awesome
Just put the video on Tumblr
http://shapeways.tumblr.com/post/5155838405/fully-articulate d-3d-printed-hand-crank-fan-by
Duann Scott
Re: Hand-Crank Fan [message #26906 is a reply to message #26892 ] Tue, 03 May 2011 16:55 UTC Go to previous messageGo to next message
avatar stuartar  is currently offline stuartar
Flinkin Blip!... single print, So COOL!
Re: Hand-Crank Fan [message #26917 is a reply to message #26885 ] Wed, 04 May 2011 00:56 UTC Go to previous messageGo to next message
Very cool !
What's the gap length you used between the parts ?
http://www.3Dizingof.com
Re: Hand-Crank Fan [message #26920 is a reply to message #26917 ] Wed, 04 May 2011 05:18 UTC Go to previous messageGo to next message
Some of the gaps are pretty tight; it really took a while to free up the parts. I'm working on some slight modifications.
There is about 1mm vertical space between the gears and the brace, and I added little semi-sphere nipples on the brace to help keep the gears from wobbling too much. I also curved the sides of the holes in the brace; a .6mm straight gap around the shafts would be too loose, but I also did not want the gap to be too small, so this is how I compromised.
index.php?t=getfile&id=8678&private=0
@vertigopolka
Re: Hand-Crank Fan [message #26921 is a reply to message #26885 ] Wed, 04 May 2011 06:12 UTC Go to previous messageGo to next message
0.3mm?? 0.4mm??
lucky you... mine arrived fused at 0.4-0.5mm Confused
Re: Hand-Crank Fan [message #26922 is a reply to message #26921 ] Wed, 04 May 2011 06:41 UTC Go to previous messageGo to next message
It took about 20 minutes to get the parts moving. I figured I was pushing the limits with some of the tolerances. I've had pieces fused before. The .4mm gap for the bumps is only at the tip/tangency, so there is a lot of space around it and didn't expect any problem there. I've tried straight cylindrical walls around axles/shafts, but they are either too loose or get fused. The rounded walls seemed to keep it from fusing, even though it's tight around the edges. I'll probably open that up, just slightly.
It's definitely difficult to try to get this all working with the WSF material.
@vertigopolka
Re: Hand-Crank Fan [message #26934 is a reply to message #26922 ] Wed, 04 May 2011 14:54 UTC Go to previous messageGo to next message
Rounded walls definately work... I tried out some dragonscale earrings with 1mm 'wire' and 0.2mm gap between the rings - image here...the rings looked like they were fused, but a few wiggles back & forth losened them up.
Did you try the 'freezer trick' to loosen up the parts?
(WillLaPuerta - It Arrived - Toy Car and Pocket Reaper)
vertigopolka - you might have a fan in hand, but you also have a fan of your designs in me.... great stuff http://www.shapeways.com/forum/images/message_icons/icon14.gif
Re: Hand-Crank Fan [message #26940 is a reply to message #26934 ] Wed, 04 May 2011 15:20 UTC Go to previous messageGo to next message
@stop4stuff: really cool earrings; it's amazing that they weren't fused! I definitely had to do a lot more than just a few wiggles on mine. I read about the "freezer trick" earlier; haven't tried that yet. Not sure if I agree with the reasoning behind it, but I would give it a try if nothing else is working. Smile
@vertigopolka
Re: Hand-Crank Fan [message #27061 is a reply to message #26940 ] Fri, 06 May 2011 20:55 UTC Go to previous message
Thanks Smile
I was pondering stuff today, musing about various things I've done with LEGO, and it struck me... LEGO is ABS with smooth surfaces, for lube on moving parts, I use a spray on silicone/PTFE oil which reduces friction to around 40%... it might not work the same with raw WSF as-is but it might work with polished/ground/sealed WSF, like after a few spins to get everything losened up and working - just a thought
Previous Topic:Custom Dog (pet) Tags
Next Topic:Nintendo Controller graduation rings
