Hi mctrivia.
Is everything OK for submitting files now?
I have the same problem. I had thought my case was exactly same as yours, but I figured out the size of file didn't matter in my case.
If the file size is somewhat large and it takes over 3 minutes(180 seconds), it fails receiving any result or error. However, the file is uploaded. There is no errors on failure just hangs the script.... same as your case.
Less than 3 minutes, everything is perfact.
As hans mentioned, I did change the code like below.
'file' => $fileHandle
but, still in the same situation.
How did you solve the problem? Did you just do what hans said?
I have tried to solve this problem for several days... checked my server, script, my computer...
Any advice would be deeply appreciated. Thanks.
JC
