Home » Community » 3D modeler needed » Ratchet Riviets
Ratchet Riviets [message #25809] Fri, 08 April 2011 12:17 UTC Go to next message
avatar toatess  is currently offline toatess
I am seeking a 3d designer to create a series of ratchet rivets for a collection of bracelets I have created. They are multiple layers of acrylic, felt and acrylic. They have a 3mm hole that lines them all up into a sandwich. I have attached a photo of a ratchet rivet to use as an example. I would like the two prong extension portions to be a tube on one and a peg on the other so they fit together cleanly. I will use a small drop of epoxy to adhere the rivet together.
The head should be around 5-6mm and rounded, shaft should extend from 6-10mm. I would like to create multiples on a single base attached with a small sprig so I can simply twist each piece off to use them. This will save having to create so many individually with 3d printing. I need 50-60 created.
Please contact me if you have any additional questions or need photos of examples or the bracelet layers.
Thank you,
Thomas
Re: Ratchet Riviets [message #25816 is a reply to message #25809 ] Fri, 08 April 2011 13:24 UTC Go to previous messageGo to next message
PM sent.
Re: Ratchet Riviets [message #25817 is a reply to message #25809 ] Fri, 08 April 2011 14:09 UTC Go to previous messageGo to next message
Please see attached photos for layers of bracelet. This is acrylic, felt and acrylic.
Also, layers could be all acrylic or acrylic and two felt. I have many combinations possible.
I would like the internal shaft to be adjustable from 5-10mm. This would cover a wide range of thicknesses. The head needs to be 5mm and like a small rounded bump.
Thomas
Re: Ratchet Riviets [message #25824 is a reply to message #25809 ] Fri, 08 April 2011 17:14 UTC Go to previous message
I want thank everyone for their interest in producing my rivets. I have chosen a designer.
Thank you,
Thomas
Previous Topic:Seeking Designer for New Home Construction Technique
Next Topic:need a little help with blender...
