| Ratchet Riviets [message #25809] Fri, 08 April 2011 12:17 UTC |
I am seeking a 3d designer to create a series of ratchet rivets for a collection of bracelets I have created. They are multiple layers of acrylic, felt and acrylic. They have a 3mm hole that lines them all up into a sandwich. I have attached a photo of a ratchet rivet to use as an example. I would like the two prong extension portions to be a tube on one and a peg on the other so they fit together cleanly. I will use a small drop of epoxy to adhere the rivet together.
The head should be around 5-6mm and rounded, shaft should extend from 6-10mm. I would like to create multiples on a single base attached with a small sprig so I can simply twist each piece off to use them. This will save having to create so many individually with 3d printing. I need 50-60 created.
Please contact me if you have any additional questions or need photos of examples or the bracelet layers.
Thank you,
Thomas
| Re: Ratchet Riviets [message #25817 is a reply to message #25809 ] Fri, 08 April 2011 14:09 UTC |
Please see attached photos for layers of bracelet. This is acrylic, felt and acrylic.
Also, layers could be all acrylic or acrylic and two felt. I have many combinations possible.
I would like the internal shaft to be adjustable from 5-10mm. This would cover a wide range of thicknesses. The head needs to be 5mm and like a small rounded bump.
Thomas
| Re: Ratchet Riviets [message #25824 is a reply to message #25809 ] Fri, 08 April 2011 17:14 UTC |
I want thank everyone for their interest in producing my rivets. I have chosen a designer.
Thank you,
Thomas
