| Submit model - [message #25464] Wed, 30 March 2011 20:48 UTC |
Hi
I'm trying to discuss with shapeways.com server to upload a zip file.
Here are the exchanges between my program and the server.
What I dont understand is why the server answers with a new session_id when I invoked the submit_model API.
Thank you for your help
seb
here are the exchanges:
POST /modules/shapeways_api/webservice/v1/soap.php HTTP/1.1
Host: localhost
Content-Type: application/soap-xml; charset="utf-8"
Content-Length: 568
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns1="urn:SW.wsdl" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<ns1:login>
<username xsi:type="xsd:string">sebtest</username>
<password xsi:type="xsd:string">my_real_password_was_there</password >
<application_id xsi:type="xsd:string">Test</application_id>
</ns1:login>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:51 GMT
Server: Apache/2.0.52 (Red Hat)
X-Powered-By: PHP/5.2.13
Set-Cookie: iep=tgg0d4d802mk44tbgsk3fal824; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Length: 532
Vary: Accept-Encoding
Content-Type: text/xml; charset=utf-8
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
session identifer found = tgg0d4d802mk44tbgsk3fal824
Host: localhost
Content-Length: 1542
<SOAP-ENV:Body>
<ns1:submitModel>
<session_id xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</session_id >
<model xsi:type="ns1:SWModel">
<desc xsi:type="xsd:string">Test</desc>
<file xsi:type="xsd:base64Binary"> VUVzREJCUUFDQUFJQU9LcGZqNEFBQUFBQUFBQUFBQUFBQUFIQUJBQWMyVmlM bmR5YkZWWURBQ29nWk5OT0lHVFRmVUJGQUJ0amtzTGdrQVVoZGZlWDNHZ2Jj V29CVzBqRWdMYkpMaUpGdUpNSlpRak5rRVIvdmZtSlFiR3dHWE9kKzdqVFBM RFBrVWV6Um1lNnJ3aXlxNUZJK2hEd0VYSXUxRHRHN3VhaTVmZ1NWR0tUQ2p0 R0JkNHlGdkZrYXpUYkVzV2xGSzJIQnRUcTdwUXdrTFhDelN5cWhXT1hnV21N UE9tTlB6bkxCeWtGdjlJTDczTmxxNTZmTEw3dTU4OE5yeS9HN2pqZWxlSUNE Rm1JVVo4TWFLbWQwek4vSmpHZW9lalBUR0pPdXJvQzFCTEJ3aFFGMzBkclFB QUFHa0JBQUJRU3dFQ0ZRTVVBQWdBQ0FEaXFYNCtVQmQ5SGEwQUFBQnBBUUFB QndBTUFBQUFBQUFBQUFCQXBJRUFBQUFBYzJWaUxuZHliRlZZQ0FDb2daTk5P SUdUVFZCTEJRWUFBQUFBQVFBQkFFRUFBQUR5QUFBQUFBQT0= </file>
<filename xsi:type="xsd:string">out.zip</filename>
<title xsi:type="xsd:string">Test</title>
<view_state xsi:type="xsd:string">1</view_state>
<tags xsi:type="xsd:string">Test</tags>
<has_color xsi:type="xsd:boolean">1</has_color>
<modeltype xsi:type="xsd:string">ZIP</modeltype>
</model>
</ns1:submitModel>
</SOAP-ENV:Body>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:52 GMT
Set-Cookie: iep=197umsugmieutsuc96481i29l4; path=/
Pragma: no-cache
Content-Length: 532
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">197umsugmieutsuc96481i29l4</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
| Re: Submit model - [message #25494 is a reply to message #25464 ] Thu, 31 March 2011 14:34 UTC |
Seb--I'll share these questions with the development team and we'll get back with more detailed answers.
Have you reviewed the documentation and code example at http://www.shapeways.com/api already?
[Updated on: Thu, 31 March 2011 16:18 UTC] Shapeways Front-End Product Lead
| Re: Submit model - [message #25778 is a reply to message #25464 ] Thu, 07 April 2011 18:49 UTC |
Seb, how are you doing? Have you had any better luck with the API, and have you been able to review our sample code?
-Ben
| Re: Submit model - [message #25867 is a reply to message #25778 ] Sun, 10 April 2011 10:34 UTC |
Hi Ben
Unfortunately, I stopped these developments and made a php one.
| Re: Submit model - [message #25924 is a reply to message #25867 ] Mon, 11 April 2011 13:59 UTC |
I'm not sure what you mean. Did you create a PHP app to work with our API, or something else entirely? Did you use any of the sample PHP code we provide for download at shapeways.com/api ?
| Re: Submit model - [message #25929 is a reply to message #25924 ] Mon, 11 April 2011 16:15 UTC |
Yes. something totally new where I send the model via HTTP POST protocol to my website. and my website just send it to shapeways.com using PHP.
| Re: Submit model - [message #25987 is a reply to message #25929 ] Tue, 12 April 2011 21:13 UTC |
We are looking forward to seeing your project once it's complete and launched!
