Home »  » Shapeways API » Submit model -
Submit model - [message #25464] Wed, 30 March 2011 20:48 UTC Go to next message
avatar sebtest  is currently offline sebtest
Hi
I'm trying to discuss with shapeways.com server to upload a zip file.
Here are the exchanges between my program and the server.
What I dont understand is why the server answers with a new session_id when I invoked the submit_model API.
Thank you for your help
seb
here are the exchanges:
POST /modules/shapeways_api/webservice/v1/soap.php HTTP/1.1
Host: localhost
Content-Type: application/soap-xml; charset="utf-8"
Content-Length: 568
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns1="urn:SW.wsdl" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<ns1:login>
<username xsi:type="xsd:string">sebtest</username>
<password xsi:type="xsd:string">my_real_password_was_there</password >
<application_id xsi:type="xsd:string">Test</application_id>
</ns1:login>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:51 GMT
Server: Apache/2.0.52 (Red Hat)
X-Powered-By: PHP/5.2.13
Set-Cookie: iep=tgg0d4d802mk44tbgsk3fal824; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Length: 532
Vary: Accept-Encoding
Content-Type: text/xml; charset=utf-8
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
session identifer found = tgg0d4d802mk44tbgsk3fal824
Host: localhost
Content-Length: 1542
<SOAP-ENV:Body>
<ns1:submitModel>
<session_id xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</session_id >
<model xsi:type="ns1:SWModel">
<desc xsi:type="xsd:string">Test</desc>
<file xsi:type="xsd:base64Binary"> VUVzREJCUUFDQUFJQU9LcGZqNEFBQUFBQUFBQUFBQUFBQUFIQUJBQWMyVmlM bmR5YkZWWURBQ29nWk5OT0lHVFRmVUJGQUJ0amtzTGdrQVVoZGZlWDNHZ2Jj V29CVzBqRWdMYkpMaUpGdUpNSlpRak5rRVIvdmZtSlFiR3dHWE9kKzdqVFBM RFBrVWV6Um1lNnJ3aXlxNUZJK2hEd0VYSXUxRHRHN3VhaTVmZ1NWR0tUQ2p0 R0JkNHlGdkZrYXpUYkVzV2xGSzJIQnRUcTdwUXdrTFhDelN5cWhXT1hnV21N UE9tTlB6bkxCeWtGdjlJTDczTmxxNTZmTEw3dTU4OE5yeS9HN2pqZWxlSUNE Rm1JVVo4TWFLbWQwek4vSmpHZW9lalBUR0pPdXJvQzFCTEJ3aFFGMzBkclFB QUFHa0JBQUJRU3dFQ0ZRTVVBQWdBQ0FEaXFYNCtVQmQ5SGEwQUFBQnBBUUFB QndBTUFBQUFBQUFBQUFCQXBJRUFBQUFBYzJWaUxuZHliRlZZQ0FDb2daTk5P SUdUVFZCTEJRWUFBQUFBQVFBQkFFRUFBQUR5QUFBQUFBQT0= </file>
<filename xsi:type="xsd:string">out.zip</filename>
<title xsi:type="xsd:string">Test</title>
<view_state xsi:type="xsd:string">1</view_state>
<tags xsi:type="xsd:string">Test</tags>
<has_color xsi:type="xsd:boolean">1</has_color>
<modeltype xsi:type="xsd:string">ZIP</modeltype>
</model>
</ns1:submitModel>
</SOAP-ENV:Body>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:52 GMT
Set-Cookie: iep=197umsugmieutsuc96481i29l4; path=/
Pragma: no-cache
Content-Length: 532
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">197umsugmieutsuc96481i29l4</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Re: Submit model - [message #25494 is a reply to message #25464 ] Thu, 31 March 2011 14:34 UTC Go to previous messageGo to next message
avatar horst  is currently offline horst
Seb--I'll share these questions with the development team and we'll get back with more detailed answers.
Have you reviewed the documentation and code example at http://www.shapeways.com/api already?
[Updated on: Thu, 31 March 2011 16:18 UTC]
Shapeways Front-End Product Lead
Re: Submit model - [message #25778 is a reply to message #25464 ] Thu, 07 April 2011 18:49 UTC Go to previous messageGo to next message
Seb, how are you doing? Have you had any better luck with the API, and have you been able to review our sample code?
-Ben
Re: Submit model - [message #25867 is a reply to message #25778 ] Sun, 10 April 2011 10:34 UTC Go to previous messageGo to next message
Hi Ben
Unfortunately, I stopped these developments and made a php one.
Re: Submit model - [message #25924 is a reply to message #25867 ] Mon, 11 April 2011 13:59 UTC Go to previous messageGo to next message
I'm not sure what you mean. Did you create a PHP app to work with our API, or something else entirely? Did you use any of the sample PHP code we provide for download at shapeways.com/api ?
Re: Submit model - [message #25929 is a reply to message #25924 ] Mon, 11 April 2011 16:15 UTC Go to previous messageGo to next message
Yes. something totally new where I send the model via HTTP POST protocol to my website. and my website just send it to shapeways.com using PHP.
Re: Submit model - [message #25987 is a reply to message #25929 ] Tue, 12 April 2011 21:13 UTC Go to previous message
We are looking forward to seeing your project once it's complete and launched!
Previous Topic:Materials list
Next Topic:email notification
