Home » Support » 3D Design » scale model with sketchup
scale model with sketchup [message #24848] Tue, 15 March 2011 16:31 UTC Go to next message
avatar studiowootwoot  is currently offline studiowootwoot
i'm trying to upload a model i've made in sketchup.
i've tried to scale it to 1/50 so it would be 9 x 9 cm, but i still get an error that the model is to big.
So the model i see in sketchup is not the same size when i upload it.
The only way to export it from sketchup is as an .dae
Can anyone help me?
greetings
Karina
Re: scale model with sketchup [message #24895 is a reply to message #24848 ] Wed, 16 March 2011 16:27 UTC Go to previous messageGo to next message
avatar bluelinegecko  is currently offline bluelinegecko
I've used sketchup for almost all the designs I've had printed up. One thing you want to look at is if your model contains any "grouped" items or components. If it does then you need to "explode" all of them AFTER you scale the model to the right size.For some reason they will still read their initial size and not the size they appear on screen if you don't explode them. I'm using sketchup8 and it works great for me without having to use any other software to convert the majority of my models.
[Updated on: Wed, 16 March 2011 16:27 UTC]
Re: scale model with sketchup [message #24920 is a reply to message #24895 ] Thu, 17 March 2011 10:23 UTC Go to previous messageGo to next message
thanks for the answer.
I've tried the things you've said, but i still get an error, now the error is "empty output".
I've made a simple 3d in sketchup just by pulling some surfaces. Is there a special way to make your models by sketchup?
thanks
greetings
karina
Re: scale model with sketchup [message #24924 is a reply to message #24848 ] Thu, 17 March 2011 14:45 UTC Go to previous messageGo to next message
I've made several models through sketchup but have never gotten that error yet. Are you using version 8?
Aside from the scaling issue I mentioned earlier I haven't had any problems. I just design in sketchup, export as a DAE file and upload it to shapeways. Everything works great. I downloaded meshlab but haven't ever had a need to do the STL conversion process they describe in the tutorial here
http://www.shapeways.com/tutorials/sketchup_3d_printing_expo rt_to_stl_tutorial
If you are going for a full color sandstone print theres a few more steps and you have to export to other programs, but for anything else this has worked great for me.
you might want to set your export options like they show on this tutorial as well and see if that works.
http://www.ponoko.com/starter-kits/google-sketchup
Can you upload a pic of your model? if all else fails I wouldn't mind taking a look at it and seeing if I could figure out whats going on with it for you.
Re: scale model with sketchup [message #25376 is a reply to message #24848 ] Mon, 28 March 2011 18:49 UTC Go to previous messageGo to next message
avatar noesis  is currently offline noesis
Hi, I've used sketchup quite a few times too, everything @bluelinegecko is saying sounds like good advice, I just wanted to throw in my workflow for reference, because I've had similar scaling issues.
Here's what I do:
Model everything scaled up (I like to work in meters and pretend they're millimeters)
When finished I save the file, then I open up the group or component of the object and use the measuring tape tool to take a measurement of a know distance, i.e. 3 meters, then before I do anything else I type in 3mm, sketchup asks if I want to rescale the active group, I say yes, it scales it.
Next I exit the group and move it to the origin point, most times I then explode the group down to bare lines.
Finally I export to .dae and upload to Shapeways
After all of that I just undo back to before I scaled the group and resave, so I can come back later and work on the model at the larger scale if needed, but my export model is at the correct size.
The process seems tedious but you get it down pretty fast. Works like a charm for me, haven't had any issues since I started doing it this way. I avoid the actual scale tool like the plague, if I use it to scale then I always get size errors.
Hope that helps!
-Noesis
Re: scale model with sketchup [message #25394 is a reply to message #25376 ] Tue, 29 March 2011 00:59 UTC Go to previous messageGo to next message
Thanksfor a new tip Noesis, I wasn't aware you could use the measuring tape tool to scale like that. I'm going to have to give that a try. I occasionally get crashes scaling my models down ( I model at larger scale too) on models with small radius curves. I'll have to try your tip and see if it solves that problem for me too.
Re: scale model with sketchup [message #36587 is a reply to message #25394 ] Thu, 13 October 2011 15:01 UTC Go to previous message
avatar andre77  is currently offline andre77
A silly problem I had with sketchup was that i forgot to delete the flat model of the human that was in my default sketchup project.
Kept on getting an error from shapeways saying my project was 66in tall.
Delete the human!
Previous Topic:Hollow design filled in?
Next Topic:QR Stamp
