Home » Community » Post Production Techniques » Polishing flat Stainless Steel surfaces
Polishing flat Stainless Steel surfaces [message #24714] Thu, 10 March 2011 15:05 UTC Go to next message
avatar InterSimi  is currently offline InterSimi
Hi everyone,
I am after a technique or indeed tools which will allow me to polish small flat surfaces to a mirror like finish.
I have previosuly used wet/dry 400 Grit and 1500 Grit by hand on a flat surface. The issue with that, is that it takes about 30 minutes per piece. I would like to cut this time down to the minimum.
The 1500 from 400 Grit isn't the issue, as that is quite quick, it is the getting it to a 400 Grit status, with the burs off. The surcase has to be completely flat.
I have tried a dremel, but this doesn't seem appropriate to get the flat surface.
Any idas or suggestions?
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #24718 is a reply to message #24714 ] Thu, 10 March 2011 15:46 UTC Go to previous messageGo to next message
The absolute fastest cutting abrasives are diamond products.
These cost more than typical aluminum oxide based abrasives but they are not exorbitant and the time savings will more than offset the added expense.
For flat surfaces like your cufflink design a simple solution would be make yourself a lapping plate by gluing a piece of waterproof abrasive paper/film, to a dead flat surface, use a piece of plate glass or a chunk of marble tile for this. Make several, one for each grit you want to use. You then just carefully rub the face of your links against this surface. Add water as a lubricant and your abrasives will work faster and last longer. Personally, I think the jump from 400 to 1500 is a bit to wide for optimum results. Most finishing manual recommend a minimum of 600 grit before beginning a polishing phase. For initial coarse cut down I never jump grits by more than 200 grit. A lot of this depends on how hard your base material is. The SS print material is quite hard in fact.
Industrial suppliers world wide sell a vast array of diamond products in varying degrees of grit from coarse to microfine. These products can take the form of water proof films (like sand paper) also tools with metal substrates onto which diamond grains are sintered. Like hand files, also grinding wheels, and points for use in a dremel rotary tool. Diamond compounds are also available in paste form which can be applied to a lapping plate or small felt polishing wheels.
In the USA a great source for these materials comes from the Gesswein Co. Otherwise just Google "diamond abrasives". I promise that if you try these materials you will never go back to standard abrasives.
-G
Leonardo da Vinci
Re: Polishing flat Stainless Steel surfaces [message #24748 is a reply to message #24718 ] Fri, 11 March 2011 11:13 UTC Go to previous messageGo to next message
Thanks for the great reply G.
The jump from 400 to 1500 wasn't so much of an issue. In fact, the 1500 portion was really quick. The longest part was using the 400 to get rid of the larger bumps and to make it smooth.
I noticed to mentioned starting off with 600 grit, but I feel that it would take even longer to get down to a smooth(ish) level before polishing with 1500 (and higher). I was toying with the idea of going lower than 400. What are your thoughts?
Also, what glue would you recommend? Ideally, something sticky, which sticks the paper to the glass (in spray form), then easily removable.
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #24753 is a reply to message #24748 ] Fri, 11 March 2011 14:40 UTC Go to previous messageGo to next message
For metalwork anything above 220 grit is really considered finishing paper. To quickly remove the print lines and bumps you need an aggressive cut down procedure. I would start with nothing finer than 80-100 grit. This will rapidly give you a clean flat surface. Be careful here and use light pressure so you don't inadvertently go to far or round over any edges. Jump from there to 220, 400, 600. During this refining phase you should alter the direction of strokes by 90 degrees each time you jump a grit. This insures that you have removed all traces left from the previous grit. From 600 upward you are really into the polishing phase. You might want to use a circular motion now. These steps are somewhat subjective and a matter of personal experience. Whatever works best for you will become the rule.
I use low tack spray adhesive for attaching papers to lapping blocks. On finer grits of paper you will find that often just a few drops of water on the block will hold the paper in place. Good luck and have fun.
-G
Leonardo da Vinci
Re: Polishing flat Stainless Steel surfaces [message #24756 is a reply to message #24714 ] Fri, 11 March 2011 15:02 UTC Go to previous messageGo to next message
Thanks a lot G. That is great advice and certainly something I will be looking at doing.
I will be ordering a dozen or so cufflinks and selling them for charity (for my work). I just didn't want to have to spend 30 minutes on each set only to have the charity earn £5!
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #25415 is a reply to message #24714 ] Tue, 29 March 2011 16:47 UTC Go to previous messageGo to next message
avatar bluelinegecko  is currently offline bluelinegecko
You might also want to try some whetstones if you have any lying around. I have a few from a knife sharpening set I purchased a long time ago. I tried one the other day on an item I ordered and it produced a beautiful mirror smooth finish. I didn't go all the way through the grits. I had all ready filed the surface flat and smoothed it with a dremel equipped with a buffing wheel and compound. But out of curiosity I hit the surface with the finest whetstone I had and I swear it looks even better than the dremel treatment did. If the stone is new it also has the benefit of maintaining a perfectly flat surface too. I don't know exactly what grit the stone was (I have to dig up the rest of the kit) and unfortunately my current digital camera is absolutely horrible at macro shots, but just thought i'd throw the idea out there if anyone wanted to give it a try.
Re: Polishing flat Stainless Steel surfaces [message #25416 is a reply to message #25415 ] Tue, 29 March 2011 17:19 UTC Go to previous messageGo to next message
I do have a selection of stones from my Japanese sword polishing days Smile I will give it a try
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #25425 is a reply to message #25416 ] Tue, 29 March 2011 21:13 UTC Go to previous messageGo to next message
Just go easy when using Japanese water stones. They are relatively soft and easy to chew up. It's a real booger to get out the grooves that might occur. A hard oil stone might be a better choice.
-G
Leonardo da Vinci
Re: Polishing flat Stainless Steel surfaces [message #25427 is a reply to message #25425 ] Tue, 29 March 2011 21:41 UTC Go to previous messageGo to next message
Thanks Glen.
I did 20 individual cufflinks the other day. I started off with 120 Grit wet and dry and worked up to 2500. It takes ages and doesn't half go through the sheets!
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #27270 is a reply to message #25427 ] Tue, 10 May 2011 20:06 UTC Go to previous messageGo to next message
You may want to consider getting a motorized horizontal polishing wheel. I am sorry I don't know the official name for it.
But a jeweler I have done work for has one, and it is a about 12 inches wide, has a steady stream of water falling on it, and you can control how fast the wheel spins. It could turn your half hour into a few minutes. Check jewelry supply stores for something that matches my description. I have no idea how much it will cost, but it could be worth it if it saves you a lot of time.
www.Craftosterone.com
Re: Polishing flat Stainless Steel surfaces [message #28585 is a reply to message #27270 ] Sat, 04 June 2011 10:36 UTC Go to previous messageGo to next message
Genius, thanks Novaking
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #28663 is a reply to message #28585 ] Mon, 06 June 2011 18:25 UTC Go to previous messageGo to next message
avatar SIXTHSCALE  is currently offline SIXTHSCALE
i've been making miniature knives and swords from steel the hard way for years before i discovered shapeways... and the best polishing method i found to get a really nice shine on blades is to get some 7 way fingernail buffers and work through the different grits from coarsest to finest...
Re: Polishing flat Stainless Steel surfaces [message #53491 is a reply to message #27270 ] Sun, 02 September 2012 02:06 UTC Go to previous messageGo to next message
LincolnK wrote on Tue, 10 May 2011 20:06
Does anyone know of the name of such a device? I have been searching for a table top version of a lapping machine or similar and they seem quite hard to find. In the US there is something called JoolTool, which looks like it would be perfect, but they only sell them in the US. I would prefer to purchase something here in the UK.
Does anybody know the name of these machines and where one might purchase one?
regards,
InterSimi
Re: Polishing flat Stainless Steel surfaces [message #53501 is a reply to message #53491 ] Sun, 02 September 2012 10:25 UTC Go to previous messageGo to next message
Try looking for a 'linisher'.
These are three UK jewellery tool suppliers
HS Walsh
Shesto
Suttons
Bill Bedford
Re: Polishing flat Stainless Steel surfaces [message #55342 is a reply to message #53491 ] Sun, 14 October 2012 19:00 UTC Go to previous message
[quote title=InterSimi wrote on Sun, 02 September 2012 02:06]
What you are looking for is a lapidary grinder/cabber
http://www.diamondpacific.net/cabber.html
Personally, I have a buffing jack.
similar to this
http://www.grainger.com/Grainger/DAYTON-Bench-Top-Buffer-1FY V4?Pid=search
I prefer the buffing jack for versatility, but getting a flat face requires some experience with the process.
bvr
Buffalo, 360° @ a time
Previous Topic:any technique to make a final good look for an iphone case in WSF? or in dyed colors?
Next Topic:Painting FUD Products
