Invert pendant
Invert pendant [message #24531] Mon, 07 March 2011 09:41 UTC Go to next message
avatar torus2  is currently offline torus2
Some kind of jewelery thing I made, suggestions/feedback?
index.php?t=getfile&id=7513&private=0
http://www.shapeways.com/model/222912/invert_pendant.html
  • Attachment: invert.jpg
    (Size: 392.06KB, Downloaded 261 time(s))
[Updated on: Mon, 07 March 2011 09:41 UTC]
Re: Invert pendant [message #24538 is a reply to message #24531 ] Mon, 07 March 2011 15:15 UTC Go to previous messageGo to next message
avatar baltimore  is currently offline baltimore
Shapeways Crew
looks cool but it looks pretty thin... probably won't be able to be build. what material are you planning?
www.Custom3dStuff.com
Re: Invert pendant [message #24575 is a reply to message #24538 ] Tue, 08 March 2011 07:15 UTC Go to previous messageGo to next message
Metal, basically. I shall go ahead and add some supporting material to the top.
Re: Invert pendant [message #24603 is a reply to message #24531 ] Tue, 08 March 2011 18:25 UTC Go to previous messageGo to next message
If you plan on ordering in stainless, 1) it has to be 3mm thick. and 2) all that unsupported geometry will probably make it unprintable.
If you plan to wait for silver, the previous minimum thickness was .5mm but you would still have issues with the unsupported geometry I believe (they print in wax, then use that to cast the silver)
Re: Invert pendant [message #24604 is a reply to message #24603 ] Tue, 08 March 2011 18:29 UTC Go to previous messageGo to next message
Unsupported geometry- what does that mean exactly? Does this would be unprintable even if I made each twist at least 3mm?
Any recommendations?
Re: Invert pendant [message #24607 is a reply to message #24531 ] Tue, 08 March 2011 18:33 UTC Go to previous messageGo to next message
What it means is, in stainless there is a green phase. Where the model is very fragile. They have to pack a support material around it to bake it. To pack around the swirls of the pendent would be difficult without breakage, and during the firing process they would most likely sag. I think it would be very difficult to get your intended result in stainless. I'm not as sure about silver, it may be more doable. But we'll have to wait to see the new guidelines when they are released.
Re: Invert pendant [message #24608 is a reply to message #24607 ] Tue, 08 March 2011 18:35 UTC Go to previous messageGo to next message
Disappointing. I shall make it non-order-able then.
Re: Invert pendant [message #24638 is a reply to message #24608 ] Wed, 09 March 2011 08:18 UTC Go to previous message
More about stainless design rules can be found in the latest blog entry (also links to updated stainless design rules) http://www.shapeways.com/blog/archives/763-New-Stainless-Ste el-Design-Rules.html
Previous Topic:Full color model on the limit of the rules?
Next Topic:Newbie issue
