| [FIXED] Garbled model in Shapeways render [message #24437] Fri, 04 March 2011 04:37 UTC |
My model, a pair of steampunk-style goggles, when uploaded, appears messed up in the 2d view.
http://www.shapeways.com/model/221755/steampunk_goggles.html
There appears to be all sorts of excess geometry which does not exist in my model. What's going on here? I re-downloaded, and checked it for anomalies- it is perfectly manifold, normals are correctly oriented.
Please help! I need to finish this urgently.
Thanks in advance
attached is an image of the Shapeways render
[Updated on: Fri, 04 March 2011 06:29 UTC]
| Re: Garbled/b0rked model in Shapeways render [message #24438 is a reply to message #24437 ] Fri, 04 March 2011 05:21 UTC |
Looks like mesh medic found some weird geometries and tried to repair them.
Could there be any tiny holes not watertight?
If not, send service and email when you upload letting them know what is going on, they may be able to fix it..
Cheers
Duann
| Re: Garbled/b0rked model in Shapeways render [message #24439 is a reply to message #24438 ] Fri, 04 March 2011 05:31 UTC |
I'm sorry, I'm not clear on what you're telling me to do :\
Who should I contact?
I did not check the 'automatically fix my model' box on upload, so why did it mess with it at all?
The mesh appears to be completely manifold, although I have used intersecting volumes. Could this be the issue? It hasn't been an issue in the past.
Thank you for your quick reply!
[Updated on: Fri, 04 March 2011 05:33 UTC]
| Re: Garbled/b0rked model in Shapeways render [message #24440 is a reply to message #24439 ] Fri, 04 March 2011 06:10 UTC |
Well, I fixed it. Turns out the issue was that two volumes came too close to sharing a face (basically z-fighting). I made them more discreet, and it worked.
Presumably Shapeways' boolean operations couldn't deal with faces in plane with each other.
Thanks anyway!
I hope this thing isn't too fragile to be printed!
| Re: Garbled/b0rked model in Shapeways render [message #24443 is a reply to message #24440 ] Fri, 04 March 2011 08:51 UTC |
cool, good luck with the goggles.
If you have any further issues contact service(at)shapeways.com
cheers
Duann Scott
