Floppy Disk Pendant
Floppy Disk Pendant [message #23975] Thu, 17 February 2011 15:39 UTC Go to next message
avatar Spongeinside  is currently offline Spongeinside
Hi all,
This afternoon I've been working a couple of hours on modeling a floppy disk!
As I'm using SketchUp, I imported an image of a floppy disk and traced it so I could get the size about right, after that I had to eyeball it somewhat to get it to work right Smile
After downscaling it to a more suitable pendant size some things deeded fixing/altering to make it pretty again.
It's now at 2mm thickness, I'm not sure if that's too thin, but I don't want to go much thicker as it'll use more material and thus costs more and the weight gets too high to be worn comfortable as a pendant Smile (and it'll start to look bad...)
I would prefer to have it printed in stainless steel, but I think a WSF version would be nice too, so people could paint it to make it look even more like a real floppy disk! =D
http://dl.dropbox.com/u/7383894/SW/Floppy_pendant_preview_small.jpg
If it ain't Dutch, it ain't much!
Re: Floppy Disk Pendant [message #23976 is a reply to message #23975 ] Thu, 17 February 2011 16:13 UTC Go to previous messageGo to next message
Unfortunately for right now all stainless must be 3mm thick
Are those 3-1/2 or 5-1/4? I'm not old enough to remember the 8" ones but I've seen them Razz
Re: Floppy Disk Pendant [message #23977 is a reply to message #23976 ] Thu, 17 February 2011 16:19 UTC Go to previous messageGo to next message
Hm.. well, I could add 1mm to it's thickness Smile Maybe that'll solve some uploading issues I've had too..
It's modeled after a 3,5" floppy disk Smile The well known \A: drive Razz
Re: Floppy Disk Pendant [message #23980 is a reply to message #23975 ] Thu, 17 February 2011 17:52 UTC Go to previous messageGo to next message
The larger ones were also A:\ I believe both the larger disks were used before hard drives were common place lol. The problem uploading is it's only 2mm in the bounding box. Rotate them so the make the bounding box larger.
Re: Floppy Disk Pendant [message #23982 is a reply to message #23980 ] Thu, 17 February 2011 19:03 UTC Go to previous messageGo to next message
I've been messing with it a bit now and managed to upload it Very Happy
Only, I noticed I've put the little loop on it incorrectly Embarassed Fixing it at the moment Smile
*edit*
Fixed! =D and available form my shop
[Updated on: Thu, 17 February 2011 19:18 UTC]
Re: Floppy Disk Pendant [message #24001 is a reply to message #23982 ] Fri, 18 February 2011 04:02 UTC Go to previous messageGo to next message
avatar ana_xyz  is currently offline ana_xyz
@Sponge, you keep on coming up with models that are cute incarnations of everyday things. Good stuff! I'm excited to see the results.
Community Manager | Shapeways
Re: Floppy Disk Pendant [message #24010 is a reply to message #24001 ] Fri, 18 February 2011 08:44 UTC Go to previous message
ana wrote on Fri, 18 February 2011 04:02
Thanks! I've ordered some prototypes in wsf to see how they work out Smile If it's all good I hope to get them in stainless steel, not all at once, but over time, as they're ~$30 each... it's pretty pricey, but if the details work out as they're supposed to, I think they'll be worth it Smile
Previous Topic:New Bracelets
Next Topic:Table lamp 'Temptation' I need help with this!
