Fixed and hollowed to 1.5mm
Fixed and hollowed to 1.5mm [message #23580] Tue, 08 February 2011 18:37 UTC Go to next message
avatar harold4  is currently offline harold4
If someone can help me please:
When I have my 3D draw how can I do to fixed it and hollowed it to 1.5mm with 3 holes under base (3 holes in bottom of the base to help the tech guys to clear all support material from the inside)?
If I don't do that my mini-statue for example will be more expansive?
Thanks a lot,
Harold. Smile
[Updated on: Tue, 08 February 2011 18:44 UTC]
Re: Fixed and hollowed to 1.5mm [message #23583 is a reply to message #23580 ] Tue, 08 February 2011 20:28 UTC Go to previous message
Yes, you need holes connecting the inside void to the outside, but they can be arbitrarily small. They don't actually need to be able to remove the support material (it is discarded anyway), but the software can't calculate the volume properly if you don't have a hole.
[Updated on: Tue, 08 February 2011 20:28 UTC]
Previous Topic:COLLADA export from Sketchup rendered improperly
Next Topic:VRML, sizing and scaling
