Home » Community » Shapeways Shops » Is it possible to rename an item?
Is it possible to rename an item? [message #23176] Sat, 29 January 2011 17:39 UTC Go to next message
I've just noticed a couple of minor errors in my spelling and capitalization in the names of items in my shop Is it posible to rename them or do I have to delete and re-add them ?
Re: Is it possible to rename an item? [message #23181 is a reply to message #23176 ] Sat, 29 January 2011 18:21 UTC Go to previous messageGo to next message
If you are logged in, you can change the title at the top of the right side bar.
The save button is at the bottom of that side bar.
If your then reload the url will also change.
Stijn
Ps. In case you are referring to shop section names, those can't be renamed. (yet)
[Updated on: Sat, 29 January 2011 18:22 UTC]
Re: Is it possible to rename an item? [message #23183 is a reply to message #23181 ] Sat, 29 January 2011 19:42 UTC Go to previous messageGo to next message
Ah I'd tried that but it didn't seem to change the title at the top left.
but when I reload the page it has changed !
Re: Is it possible to rename an item? [message #44719 is a reply to message #23183 ] Thu, 01 March 2012 17:00 UTC Go to previous messageGo to next message
avatar VFXrex  is currently offline VFXrex
can you rename your models? i named a couple of my models and i want to change the name, and not reload all of them. what is the exact process of renaming a model on the site? thank you, thomas
VFXrex.com
Re: Is it possible to rename an item? [message #45058 is a reply to message #44719 ] Thu, 08 March 2012 10:12 UTC Go to previous messageGo to next message
Hi Thomas,
If you've not figured it out yet, the re-naming prcedure is quite simple - goto the model page when logged-in, click on 'edit' so that 'edit' is set to on then click on the title of the model to change it - hit return after changing the text to make the name stick.
Re: Is it possible to rename an item? [message #45668 is a reply to message #23176 ] Sun, 18 March 2012 21:43 UTC Go to previous message
avatar skatersollie  is currently offline skatersollie
Just go to you model click on the edit button and then double click on the name of your model...It looks like the option is not there because there is no button or field to enter, but once you double click on title or name of your model you should get the generic text cursor to show up and its simple as just changing typing a new name..
[Updated on: Sun, 18 March 2012 21:44 UTC]
http://www.skatersollie.com
Previous Topic:Looking for an advice
Next Topic:Shop Image Order
