Changes to max cost of a co-creator
Changes to max cost of a co-creator [message #23027] Tue, 25 January 2011 20:21 UTC Go to next message
avatar pittance  is currently offline pittance
I'm not sure if I'm doing something wrong but I've tried to change the maximum cost of a co-creator (I had a problem with the code I use to create it that left material where I don't really need it) and I can't.
I've unpublished the template to see if I can change the settings but the one I need (the maximum cost) is still greyed out. Is there a way to fix this?
Thanks for any help...
Chris
Re: Changes to max cost of a co-creator [message #23033 is a reply to message #23027 ] Tue, 25 January 2011 21:10 UTC Go to previous messageGo to next message
Did you change the volume?
Re: Changes to max cost of a co-creator [message #23072 is a reply to message #23033 ] Wed, 26 January 2011 20:47 UTC Go to previous messageGo to next message
Yes - I've changed the generator code so that any model made with it can now have a slightly lower volume.
I tried updating the model with a new one from the new code and the current volume changes but it doesn't seem to want to allow me to change the maximum value at any point.
Re: Changes to max cost of a co-creator [message #23073 is a reply to message #23027 ] Wed, 26 January 2011 20:52 UTC Go to previous messageGo to next message
I'm a little confused, what do you mean by the maximum cost? Can you put up a screen shot of the area you're referring to?
Re: Changes to max cost of a co-creator [message #23113 is a reply to message #23073 ] Thu, 27 January 2011 20:14 UTC Go to previous messageGo to next message
This is the 'Manage Template Details' section of the design's page that I got to from 'My Designs'
I've attached a screenshot of what this section looked like when I un-published the co-creator just now - the maximum volume is at the bottom and is now incorrect, the current volume is OK (it's the volume of the model that's shown in the picture illustrating the co-creator).
index.php?t=getfile&id=6825&private=0
I entered the max volume when I first converted the model into a co-creator but I now can't change this number.
Re: Changes to max cost of a co-creator [message #23114 is a reply to message #23027 ] Thu, 27 January 2011 20:21 UTC Go to previous messageGo to next message
Ah, so I figured. I'll inform the powers that be.
Re: Changes to max cost of a co-creator [message #23154 is a reply to message #23027 ] Fri, 28 January 2011 16:09 UTC Go to previous messageGo to next message
Anonymous Coward
I'm guessing this is a one-off glitch and not a platform problem, so we'll QA and see what we can find. At the moment I can reassure you that this issue is on our radar!
Re: Changes to max cost of a co-creator [message #23200 is a reply to message #23154 ] Sun, 30 January 2011 11:19 UTC Go to previous message
avatar barrys  is currently offline barrys
Hi pittance,
On the screenshot you provide, the max volume doesn't appear to be greyed out, nor that you couldn't change it. I tried a random cocreator of myself and it does seem to work ok. Can you tell me the model id or title that seems to be a problem with.
Barry
Previous Topic:Bugging 3d viewer java applet
Next Topic:option to set markup for all materials
