Here is an example with text inside. It's possible we borked the original Text node. We've been moving to this pattern of using a Text2D datasource feed into a Image3D(that's what the Text was doing under the covers anyway).
var params = [
label: "Ring Size",
desc: "US Ring Size",
type: "double",
rangeMin: 0,
rangeMax: 16,
step: 0.25,
defaultVal: 11
desc: "Ring Width",
label: "Ring Width",
type: "double",
rangeMin: 1,
rangeMax: 10,
step: 0.1,
defaultVal: 2,
unit: "MM"
label: "Pattern Image",
desc: "Image",
type: "uri",
defaultVal: "
https://www.shapeways.com/rrstatic/img/shapejs/creator/sw_log o.png",
group: "Image"
label: "Use Grayscale",
desc: "Use Grayscale",
type: "boolean",
defaultVal: false,
group: "Image"
desc: "Scale Image to fit ring",
type: "double",
rangeMin:0.1,
rangeMax:1.25,
step: 0.01,
defaultVal: 0.95,
group: "Image"
label: "Text",
desc: "Text",
type: "string",
group: "Text"
label: "Style",
desc: "Font",
type: "enum",
values: ["HelveticaRounded LT Std Bd"],
group: "Text"
desc: "Text Height(pt)",
type: "double",
rangeMin:6,
rangeMax:20,
step: 1,
defaultVal: 7,
group: "Text"
desc: "Text Depth",
type: "double",
rangeMin: 0.2,
rangeMax: 0.8,
step: 0.1,
defaultVal: 0.4,
unit: "MM",
group: "Text"
var vs = 0.04*MM;
var POINT_SIZE = 25.4 * MM / 72;
var TORAD = PI / 180;
function ringSizeToDiameter(size) {
var diameter = 11.63*MM + (0.8128 * MM * size);
return diameter;
function makeImage(path, width, height, thickness,gray){
var img = new Image3D(path, width, height, thickness);
img.setBaseThickness(0.0);
img.setBlurWidth(0.5*vs);
if (gray == true) {
img.setUseGrayscale(true);
img.setBaseThreshold(0.01);
} else {
img.setUseGrayscale(false);
img.setBaseThreshold(0.5);
img.setImagePlace(Image3D.IMAGE_PLACE_BOTH);
img.setImageType(Image3D.IMAGE_TYPE_EMBOSSED);
return img;
function makeText3D(args) {
var text2d = new Text2D(args.text);
text2d.setFontName("HelveticaRounded LT Std Bd");
text2d.setFontStyle(Text2D.BOLD);
var bandLength = ringSizeToDiameter(args.size) * Math.PI;
var tbx = bandLength;
var tby = (args.textSize * POINT_SIZE);
var tbz = 2*args.textDepth;
var tvs = 0.05 * MM; // text voxel size
text2d.setInset(2 * tvs);
text2d.setVoxelSize(tvs);
text2d.setFit("vertical"); // vertical, horizontal, both
text2d.setHorizAlign("center"); // left, right, center
text2d.setWidth(tbx);
text2d.setHeight(tby);
var imgBox = new Image3D(text2d,tbx,tby, tbz, vs);
imgBox.setUseGrayscale(false);
imgBox.setBaseThickness(0);
imgBox.setBaseThreshold(0.5);
imgBox.setBlurWidth(0.1*MM);
return imgBox;
function main(args){
// see signet_ring.svg for drawing
// user definable variables
var imageThickness = 0.75*MM;
var ringSize = ringSizeToDiameter(args.size);
var ringThickness = 1.5*MM;
var ringWidth = args.ringWidth;
var bezelAngle = Math.PI/8; // angle of bezel sides, good values are between PI/5 and PI/20
var bezelHeight = 1.5*MM; // thickness of the ring bezel
var imagePath = args.image;
var imageScale = args.imageScale; // size of image relative to bezel size
// end of user definable variables
var inRad = ringSize/2;
var outRad = inRad + ringThickness;
var By = inRad + bezelHeight;
var sinA = Math.sin(bezelAngle);
var BC = (Ay - By)*Math.tan(bezelAngle);
var Ay = outRad/sinA;
var Fy = Ay*sinA*sinA;
var bezelBase = Fy;
var bezelTop = By;
var margin = 0.2*MM;// empty space around object
// size of grid to fit the ring
var gridWidth = 2*outRad + 2*margin;
var gridHeight = 2*bezelTop + 2*margin;
var Cx = (Ay - By)*Math.tan(bezelAngle);
var Dx = Cx*(1 + bezelHeight/(Ay - By));
var cutR = inRad; // radius of cylindrical transition
var Ex = ringWidth/2 + cutR;
var dd = 1*MM; // width of small bezel undercut
var Ey = inRad - Math.sqrt(cutR*cutR - (Ex - Dx + dd)*(Ex - Dx + dd));
var imageWidth = imageScale*Cx*2;
var imageHeight = imageWidth;
var image = makeImage(imagePath, imageWidth, imageHeight,2*imageThickness,args.useGrayscale);
var imageTransform = new CompositeTransform();
imageTransform.add(new Rotation(new Vector3d(1,0,0), -Math.PI/2));
imageTransform.add(new Translation(0,By, 0));
image.setTransform(imageTransform);
var ringBase = new Sphere(outRad);
// bezel is cone truncated by 2 parallel planes
var bezel = new Intersection();
bezel.add(new Cone(new Vector3d(0,Ay, 0), new Vector3d(0,-1,0), bezelAngle));
bezel.add(new Plane(new Vector3d(0,1,0), bezelTop));
bezel.add(new Plane(new Vector3d(0,-1,0), -bezelBase));
bezel.setBlend(0.1*MM);
var ring = new Union();
ring.add(ringBase);
ring.add(bezel);
var cutoff = new Union();
var gw = gridWidth;
var gw2 = gridWidth/2;
var thru = new Cylinder(new Vector3d(0, 0, -gw2),new Vector3d(0,0,gw2),inRad);
cutoff.add(new Cylinder(new Vector3d(-gw2, Ey, Ex), new Vector3d(gw2, Ey, Ex), cutR));
cutoff.add(new Cylinder(new Vector3d(-gw2, Ey, -Ex), new Vector3d(gw2, Ey, -Ex), cutR));
cutoff.add(new Box(0,-inRad, Ex, gw, 2*(inRad+Ey), 2*cutR));
cutoff.add(new Box(0,-inRad, -Ex, gw, 2*(inRad+Ey), 2*cutR));
var partialRing = new Subtraction(ring,thru);
partialRing.setBlend(1*MM);
var fullRing = new Subtraction(partialRing, cutoff);
fullRing.setBlend(0.1*MM);
var ringWithImage = new Subtraction(fullRing, image);
var result = ringWithImage;
if (args.text !== undefined) {
var text = makeText3D(args);
var trans = new CompositeTransform();
trans.add(new Rotation(0,0,1,180*TORAD));
trans.add(new Rotation(0,1,0,180*TORAD));
trans.add(new RingWrap(ringSizeToDiameter(args.size) / 2));
trans.add(new Rotation(1,0,0,90*TORAD));
trans.add(new Rotation(0,0,1,0*TORAD));
text.setTransform(trans);
result = new Subtraction(result,text);
var bounds = new Bounds(-gridWidth/2, gridWidth/2, -gridHeight/2, gridHeight/2, -gridWidth/2, gridWidth/2);
var scene = new Scene(result,bounds,vs);
scene.setName("SignetRing");
return scene;
