Home » Support » 3D Design » Little help needed
Little help needed [message #22430] Mon, 10 January 2011 21:43 UTC Go to next message
Hi all,
I've been having some issues lately with uploading.
since 2months several models of mine won't shop up in my shop how to have to be.
Some parts of the model are missing.
i know this could be because of the shells - when using 3ds max,, you will always have shells,,, using union screws your model when having more then 1000poly :S -
but before i never had problems with shells,, and shapeways accepted it,, and showed it perfectly.
http://www.shapeways.com/model/199089/1snel.html?gid=ug16518
as you can see on the model,, some seats are gone....
but if you check the file in the attachment,, you see there are several more seats then in the model that is uploaded (same file)
Can somebody check my file and see how I or we can fix this?
thanx in advance
Re: Little help needed [message #22445 is a reply to message #22430 ] Tue, 11 January 2011 07:41 UTC Go to previous messageGo to next message
Not sure, but it might just be some volumes are inside out?
The 3d view fails for me on this object, so I can't see what happened to it on the server.
I did see another topic where someone had multiple shells whereby some were cut out instead of added.
Anyway, if that is it, Max has a tendency to flip the normals of an object when using mirror or negative scaling.
Which max version do you use?
You could try the Shapeways Maxscript I wrote. It has an option to detect negative volumes.
(no option to fix them though, if need be I could whip something up Wink
Stijn
Re: Little help needed [message #22449 is a reply to message #22445 ] Tue, 11 January 2011 11:24 UTC Go to previous messageGo to next message
Stijn,
thanc for trying to help, but no luck i'm afraid!
normals aren't a problem for me!
when object is flipped,, i press the "reset xform" and then i can see wich objects are flipped,, by selecting the model then, i can flip normals!
so everything is in the same direction!
Does somebody know what to do?
thanx in advance
Mitchell
Re: Little help needed [message #22450 is a reply to message #22449 ] Tue, 11 January 2011 12:41 UTC Go to previous messageGo to next message
You've got overlapping faces, probably caused by a symmetry going wrong, resulting in pieces being merged with broken geometry and thus consequentially getting trashed away.
Kaetemi
Re: Little help needed [message #22451 is a reply to message #22450 ] Tue, 11 January 2011 12:44 UTC Go to previous messageGo to next message
Kaetemi,
but why is this happening to some of the seats,, and not all?
cause all of the seats are the same?
Re: Little help needed [message #22452 is a reply to message #22451 ] Tue, 11 January 2011 12:45 UTC Go to previous messageGo to next message
Apparently they're not...
http://dl.kaetemi.be/shapeways/jettuh_overlap.png
Kaetemi
Re: Little help needed [message #22453 is a reply to message #22430 ] Tue, 11 January 2011 12:45 UTC Go to previous messageGo to next message
One thing I notice about your model is that the left and right edges of the adjacent seats are right on top of each other. That's always asking for trouble, but I don't think it would make random ones disappear. It does sound like a bad transform/mirror but if you've already looked at that I'd send them separate from the car and see if the error still occurs.
I also noticed you model is (fixed) with Netfabb? I tried using Netfabb for awhile because I know Shapeways uses it, so I thought it would be more compatible, but I notice it often breaks complex models that uploaded fine before! Errors like the first one I described with coincident faces can become even worse when Netfabb tries to join everything together. It makes a mess that will confuse MeshMedic.
Try making the components work first before you combine everything.
Re: Little help needed [message #22454 is a reply to message #22453 ] Tue, 11 January 2011 12:51 UTC Go to previous messageGo to next message
I'd say the nearby face overlap is causing the meshmedic to invert the geometry so it's substracted instead of added onto the mesh. You can see the floor taken away in the render here on shapeways.
It's likely related to http://www.shapeways.com/forum/index.php?t=msg&th=4254&a mp;start=0&
Kaetemi
Re: Little help needed [message #22456 is a reply to message #22454 ] Tue, 11 January 2011 12:54 UTC Go to previous messageGo to next message
Ok, thanx!
i'm going to try fixing the overlapping stuff!
i hoped netfabb would have solved those issues for me!
I allready got the plate below the seats to have none overlapping faces!
now the seats!
Kaetemi, which program do you use?
Mitchell
Re: Little help needed [message #22457 is a reply to message #22456 ] Tue, 11 January 2011 13:09 UTC Go to previous messageGo to next message
It's the xView feature that's built into 3ds Max 2010.
Parallel overlap is somewhat difficult to process, because floating point inaccuracies will lead to undefined states.
Two parallel overlapping faces that share an edge might be a possible cause, as this would create an undefined state where the resulting zero-volume volume where the faces overlap is neither correctly oriented nor inverted, nor does it have a slicing line for the planes, nor does it connect two meshes to each other.
Or maybe something else, but overlapping parallel planes are never a good idea. =)
As easily demonstrated by 3dsMax's ProBoolean:
http://dl.kaetemi.be/shapeways/mesh_overlap_proboolean.png
(Netfabb fixes the above issues though...)
[Updated on: Tue, 11 January 2011 13:34 UTC]
Kaetemi
Re: Little help needed [message #22458 is a reply to message #22457 ] Tue, 11 January 2011 13:34 UTC Go to previous messageGo to next message
thanx Kaetemi!
tried to weld the vertics that were shown by xView!
now i think i've found the problem!
My model is made 1:1..... so the points are not that close to eachother... xView says only 34 vertics are overlapping..
now the problem is (what i think) is that i scale my model down to 1:160!
this way all vertics will be scaled down, and if the tolerance isn't high enough, mesh medic would think they overlapse eachother
could that be the thing?
edit: this is the stl file before being scaled down and before netfabb fix
[Updated on: Tue, 11 January 2011 13:39 UTC]
Re: Little help needed [message #22459 is a reply to message #22458 ] Tue, 11 January 2011 13:48 UTC Go to previous messageGo to next message
Which program and file format do you use for downscaling?
Kaetemi
Re: Little help needed [message #22460 is a reply to message #22459 ] Tue, 11 January 2011 13:50 UTC Go to previous messageGo to next message
STL, by using netfabb!
when i did in 3ds max,,, there was even less model when uploaded to shapeways!
Re: Little help needed [message #22461 is a reply to message #22460 ] Tue, 11 January 2011 13:54 UTC Go to previous messageGo to next message
Okay, here's a trick:
- Open stl in MeshLab (hit ok on a warning)
- Save as x3d (remove the normal checkboxes)
- Scale 0.00625 (it's hidden in some menu that says normals, curvature etc)
- Save
- Open x3d in netfabb
- Save as stl binary
- Profit!
3dsmax and netfabb are bad at heavy scaling operations...
MeshLab probably does some sanity checks while scaling. Saving as x3d also seems to have higher precision. Netfabb is particularly good at properly saving as STL. And don't go for uploading directly as X3D in this case, because then you'd have to scale it down even further to meter units.
[Updated on: Tue, 11 January 2011 14:03 UTC]
Kaetemi
Re: Little help needed [message #22462 is a reply to message #22461 ] Tue, 11 January 2011 14:05 UTC Go to previous messageGo to next message
I'm trying your way now.
but i can't save in x3d? says can't load libxiot.dll
so trying trough 3ds max now.
your scaling in 0.00625 , i'm scaling in 0.00627 haha
but your uploaded file works Surprised wtf your amazing!
gonna try it now myself using the 0.00627
thanx a lot
edit: got x3d working,, was having an old version of nettfab!
edit: read it wrong,, you said meshlab! gosh long time ago i used meshlab haha
[Updated on: Tue, 11 January 2011 14:23 UTC]
Re: Little help needed [message #22464 is a reply to message #22462 ] Tue, 11 January 2011 14:30 UTC Go to previous messageGo to next message
Kaetemi,
when i scale it in meshlab,, and open it then in netfabb,, it says it's like 100x as big as the 1:1 scale?
when uploaded:
The size is 2570820.10 x 1384423.15 x 132544.11 cm / 1012133.90 x 545048.48 x 52182.72 inch.
oftewel, veelste groot?
ik heb precies zoals je zei gedaan in meshlab?
save x3d,,, scale 0.00627 save xd3
en als ik hem dan in netfabb open is hij ineens heeel groot ipv heeeel klein?
[Updated on: Tue, 11 January 2011 14:49 UTC]
Re: Little help needed [message #22465 is a reply to message #22464 ] Tue, 11 January 2011 14:53 UTC Go to previous messageGo to next message
http://dl.kaetemi.be/shapeways/exportscaleflow.png
en mm selecteren bij het uploaden? Smile
[Updated on: Tue, 11 January 2011 14:55 UTC]
Kaetemi
Re: Little help needed [message #22466 is a reply to message #22465 ] Tue, 11 January 2011 14:57 UTC Go to previous messageGo to next message
Nu wordt ik helemaal gek!
Heel erg bedankt Kaetemi voor de plaatjes!
maar geloof het of niet! ik krijg
index.php?t=getfile&id=6562&private=0
ik zie wel dat je "freeze Matrix" bij scale heb aanstaan, ik heb heel dat icoontje niet!
eens ff nieuwe versie van meshlab downloaden!
misschien dat het daaraan ligt Confused
  • Attachment: kaetemi.JPG
    (Size: 28.76KB, Downloaded 262 time(s))
Re: Little help needed [message #22467 is a reply to message #22466 ] Tue, 11 January 2011 14:58 UTC Go to previous messageGo to next message
Ik heb
MeshLab 1.3.0b en netfabb 4.5.0
Kaetemi
Re: Little help needed [message #22468 is a reply to message #22467 ] Tue, 11 January 2011 15:00 UTC Go to previous messageGo to next message
hmmm die heb ik ook!
heb je nog bepaalde settings aangepast @ meshlab of netfabb?
Re: Little help needed [message #22469 is a reply to message #22468 ] Tue, 11 January 2011 15:02 UTC Go to previous messageGo to next message
Wat als je in MeshLab rechtstreeks naar stl export na het scalen?
Kaetemi
Re: Little help needed [message #22470 is a reply to message #22469 ] Tue, 11 January 2011 15:05 UTC Go to previous messageGo to next message
Dan werkt hij wel in Netfabb!
ik ga eens proberen als ik hem nu upload!
thanx Very Happy
Re: Little help needed [message #22472 is a reply to message #22470 ] Tue, 11 January 2011 15:09 UTC Go to previous messageGo to next message
YOU ARE MY HERO!
thank you a lot!
it worked!
paying and ordering it now!
Re: Little help needed [message #22474 is a reply to message #22430 ] Tue, 11 January 2011 15:33 UTC Go to previous messageGo to next message
haha guys if you don't write in English how could others learn? Razz
@Jettuh see attached in case some parts still disappear.
http://www.3Dizingof.com
Re: Little help needed [message #22475 is a reply to message #22474 ] Tue, 11 January 2011 15:36 UTC Go to previous message
Dizingof,
if you follow kaetemi's post with the pictures, you get a file where nothing is dissapearing!
Previous Topic:Measuring...
Next Topic:Pipeline for fixing a model that won't print.
