| Dwarf Fighter [message #21999] Thu, 30 December 2010 20:12 UTC |
I am having some issues uploading this model to Shapeways. The model is failing the processing with the following error: "error while unifying: 17".
Does anyone know what causes this type of error? I'm afraid it might be due to the large number of overlapping objects I have used to create a scale mail effect. The stl is attached. See the image(s) in following post(s) for reference.
| Re: Dwarf Fighter [message #22002 is a reply to message #21999 ] Thu, 30 December 2010 20:28 UTC |
Did you check the autofix button? I've opened in blender and meshlab. Meshlab says it's manifold. The model looks clean and everything. Not sure what caused the error. But I'll see if I can't find anything.
| Re: Dwarf Fighter [message #22003 is a reply to message #22002 ] Thu, 30 December 2010 21:09 UTC |
| Youknowwho4eva wrote on Thu, 30 December 2010 20:28 | Did you check the autofix button? I've opened in blender and meshlab. Meshlab says it's manifold. The model looks clean and everything. Not sure what caused the error. But I'll see if I can't find anything.
Thanks for looking. I am not entirely sure what you mean by "autofix". On this upload attempt, I did check the box for fixing it manually if the upload fails. I checked for manifold in Blender before I exported to stl, and I imported in netfabb and fixed the issues that cropped up from the object export (flipped normals, a few holes, etc.)
Beyond that, can you explain what you mean by the "autofix button"?
| Re: Dwarf Fighter [message #22004 is a reply to message #21999 ] Thu, 30 December 2010 21:42 UTC |
I'm thinking of opening a "Fix my damn STL " website
I attach 2 stls - both fixed - one hollow with a wall thickness of 1.5 mm which saves you money. (you can scale it to a larger size)
Cheers
Attachment: Archive.zip
(Size: 10.97MB, Downloaded 51 time(s))
http://www.3Dizingof.com
| Re: Dwarf Fighter [message #22006 is a reply to message #21999 ] Thu, 30 December 2010 23:00 UTC |
It had the usual intersecting triangles/bad edges etc errors which i think MeshMedic should have fixed them for you easily or by checking the "fix my model manually" box.
Great design !
Cheers
| Re: Dwarf Fighter [message #22007 is a reply to message #22006 ] Thu, 30 December 2010 23:06 UTC |
| dizingof wrote on Thu, 30 December 2010 23:00 | It had the usual intersecting triangles/bad edges etc errors which i think MeshMedic should have fixed them for you easily or by checking the "fix my model manually" box.
Great design !
Cheers
Well, I just got it to upload successfully, so what you did seems to have worked. The hollow did not work well, though. A hole was created in the back of the left leg. It looks like you may have used a boolean tool to "subtract" the inside of the model?
If I may ask, though, I really would like to know *what* you did to eliminate those edge errors. Did you use a particular tool? MeshMedic was unable to fix the errors, according to the notification e-mail.
I apologize for being insistent here - I just want to incorporate your knowledge so I don't have to bug other folks with my problems in the future.
| Re: Dwarf Fighter [message #22062 is a reply to message #21999 ] Mon, 03 January 2011 13:30 UTC |
"fix my model manually" That's what I meant by autofix.
