The design was made for a FDM printing head cooler.
Function:
The filament starts from above and moves through the "cold end"
The yellow part is the "heat break"
The heat block & nozzle is mounted on the lower thread. (not shown )
So the main function of the heat break is, to separate the ~ 220° lower area from the cooled upper area.
This is the reason, why there´s an area without thread, to reduce heat transfer as much as possible.
( 1mm wall thickness only)
https://skfb.ly/N6Tp
I´ve tried to design a efficient light weight water cooler,- instead of the conventional air cooling with cooling fins.
I don´t want to simplify the design, because it would decrease efficiency.
Edit: & idealy it should work "out of the box" ... to cut only one thread.
Not acceptable to make this from 2-3 separate parts & extra sealings etc. ... too much work.
Maybe, I have just to wait a little bit for new 3D technologies... ( and acceptable prices )
