Hexbox
Hexbox [message #20749] Fri, 19 November 2010 18:39 UTC Go to next message
Shapeways Crew
The Hexbox arrived!
I don't know if you remember the Dodbox.
This model as some common points. It is a box made of two identical parts. And you can also stack several boxes one on top of the other.
The principle is that one side out of two is connected to the top of the box and the others sides to the bottom, as you can see from the colors.
index.php?t=getfile&id=5972&private=0
I have seen some cube-shaped boxes that open this way (in transparent plastic or even in wood) and they are not so easy to open.
But in this case, it is even more difficult. This is because when you grab the box, you tend to grab it by two opposite faces - if not the box slides on yours fingers - and in this case (at the contrary of a cube) they are of "two different colors". Even more, If you use two hands, you multiply the difficulty by two (placing properly the fingers of one hand is not enough)!
So basically, even if it can open without friction, when you spontaneously grab it, it will not fall apart.
To open it, the fingers of one hand must be on the red faces, and the fingers of the other hand on the black one.
index.php?t=getfile&id=5973&private=0
(well, on this picture, I am cheating because the box is lying on a table and because I use the pegs to avoid that the box slides)
Once you know that, it is easier... but no so much!
Imagine if it was printed in a single color!
I think we can consider it is a kind of puzzle. It is always funny to see your friends struggling to open it (and using brute force) even after you show them how to do... Laughing
It is a little bit expensive because the sides have to be thick (3mm in this case), and you have to buy two halves to make a complete box.
There is a version with pegs and holes that you can be stacked:
index.php?t=getfile&id=5974&private=0
and a version without pegs and holes that I printed in Transparent Detail so that it looks like a crystal (unfortunately, I printed only one Sad )
index.php?t=getfile&id=5975&private=0
Enjoy!
index.php?t=getfile&id=5976&private=0
  • Attachment: IMG_0996.jpg
    (Size: 55.89KB, Downloaded 403 time(s))
  • Attachment: IMG_0997.jpg
    (Size: 57.99KB, Downloaded 409 time(s))
  • Attachment: IMG_1012.jpg
    (Size: 43.91KB, Downloaded 411 time(s))
  • Attachment: IMG_1004.jpg
    (Size: 56.63KB, Downloaded 418 time(s))
  • Attachment: hexbox_all.jpg
    (Size: 51.29KB, Downloaded 424 time(s))
[Updated on: Fri, 19 November 2010 19:23 UTC]
Re: Hexbox [message #20754 is a reply to message #20749 ] Fri, 19 November 2010 20:46 UTC Go to previous messageGo to next message
Cool! Clever use of lego-like connections for stacking.
Reminds me of a Pennyhedron, which also is made from two (mirror image) pieces. It has the same problem in that you need to use a tricky 3-fingered grasp to take it apart, and the sliding axis is even better hidden. I made a 3D printed version I called a pillowhedron.
Re: Hexbox [message #20758 is a reply to message #20754 ] Fri, 19 November 2010 21:46 UTC Go to previous messageGo to next message
Shapeways Crew
Thanks Gibell.
Very interesting link and model. Initially, for the Detail Transparent one, I wanted to make the top (and bottom) of the box like an hexagonal pyramid to give it the shape of a crystal. I did not realise that a rhombic dodecahedron was also possible!
[Updated on: Sat, 20 November 2010 00:34 UTC]
Re: Hexbox [message #20780 is a reply to message #20758 ] Sat, 20 November 2010 16:35 UTC Go to previous message
Shapeways Crew
I posted a video of the Hexbox.
It give a better idea of how it opens.
Previous Topic:VITRUVIUS | Vitruve | Vetrovius as Glen G said
Next Topic:More postmodern jewelry
