| QASHQAI Flip Key DIY [message #20587] Tue, 16 November 2010 18:51 UTC |
Flip Key (V4) for Nissan Qashqai
Parts needed:
- Original Qashqai key
- Top Shell
- Bottom Shell
- Flip key mechanics with uncut blade
Original Qashqai key:
You already have this key, and it is the reason you are reading this page
You can buy shell here at shapeways:
http://www.shapeways.com/shops/be_on_edge
Top Shell
Bottom shell
is it possible to add a personalized text (send me a PM with details)
| Re: QASHQAI Flip Key DIY [message #20590 is a reply to message #20587 ] Tue, 16 November 2010 18:58 UTC |
Wow. Nice tutorial. I was thinking about doing similar with my Honda Civic key.
| Re: QASHQAI Flip Key DIY [message #21067 is a reply to message #21054 ] Mon, 29 November 2010 19:58 UTC |
| Jettuh wrote on Mon, 29 November 2010 16:31 | very nice tutorial!
Thanks !
| Re: QASHQAI Flip Key DIY [message #25404 is a reply to message #23373 ] Tue, 29 March 2011 09:28 UTC |
I have just ordered the shell, but I have some questions.
Are the screws included? In case they are not, what kind of screws should I get?
How difficult is to extract the electronics from the original key? could you add some picturers or video?
| Re: QASHQAI Flip Key DIY [message #25405 is a reply to message #25404 ] Tue, 29 March 2011 09:59 UTC |
Screw are included with the mechanics,
Extracting the electronics from original key is easy as change the battery.
Did you read the instruction over here ?
Francesco
| Re: QASHQAI Flip Key DIY [message #25482 is a reply to message #25405 ] Thu, 31 March 2011 11:27 UTC |
Yes, I watched to the videos and read the assembly instructions that you provided in the post.
I was just curious about the way to extract the electronics from the original key.
[Updated on: Thu, 31 March 2011 11:28 UTC]
| Re: QASHQAI Flip Key DIY [message #46401 is a reply to message #43751 ] Tue, 03 April 2012 17:33 UTC |
MORE INFOS ABOUT SCREEWS
Usually the screws you need to join the sheels comes with the mechanincs that need to be bought as seen in the instructions page. I usually sugges, if more screew are needed to come in an hardware store with them and buy similar ones.
In terms of kind of screews any one like: Triangular self tapping screws.
Definition in wikipedia says: Other screw threads are designed to cut a helical groove in a softer material as the screw is inserted .
Head of screew should be "button" type or "flat" type.
Lenght anything betwen: 5 and 8 mm
I do suggest "Phillips" type of socket, but any type is ok as soon as you own the proper screewdriver.
Diameter of the treadh is like 2 mm, but could be little more, the material is kinda elastic.
Hope this helps.
