I would like Shapeways to provide a mechanism for running a parametric OpenSCAD script on their servers from ShapeJS with the output being pulled into ShapeJS for further manipulation.
Having uploaded an OpenSCAD script to the Shapeways server (assuming appropriate security, etc.), then in ShapeJS I would like to be able to code something like:
var openSCADParam = {thickness:3, radius:50};
distData = createModelDistanceOpenSCAD("mug.scad",openSCADParam,0.5*MM,100*MM);
In the background OpenSCAD would be run with parameters being passed to the script via variables:
openscad -o mug.stl -D thickness="3" -D radius="50" mug.scad
ADVANTAGES
1) It provides a gentle transition route for existing OpenSCAD code and programmers.
2) It avoids forcing designers to choose between OpenSCAD & ShapeJS. They can choose to code in OpenSCAD and then write a minimal ShapeJS UI.
3) It provides ShapeJS with an optional boundary representation front end that is then complimented by ShapeJS's unique functional representation capabilities.
4) It could provide easy access to the exisiting large collection of public domain parametric OpenSCAD scripts for non-programmers, e.g. the best of parametric OpenSCAD on Thingiverse could be provided on Shapeways with easy to use UIs for non-programmers.
ISSUES
1) OpenSCAD rendering can be very slow, so the real time nature of the ShapeJS UI may be impaired.
2) Added complexity through indirectly supporting an extra design language.
What do you think?
Thanks.
