| Shapeways site update of October 7th 2010 [message #18783] Thu, 07 October 2010 08:34 UTC |
Hi All,
Today we have had another site-update. The changes applied today may be less noticeable for you but are a major improvement to our developers.
We had no site update release in the last 2 weeks because of the major work that has been done. We have made a lot of changes in underlying architecture of the site and that cost more time to prepare and test.
A lot of code has been rewritten without any functionality or layout changes for perspective to the user, but these rewrites will make future development a lot easier.
Because of the major changes, also the update today took a bit longer as usual. Sorry for the inconvenience.
Additional to the architectural rewrites, the following features are introduced:
Register for newsletter on signup page
Users are be able to immediately sign up for our newsletter on the sign up page for a Shapeways account.
Expand search box onclick
Clicking the search field for the google site search makes the search field larger.
Also we applied fixes for the following issues:
- Deleting the last category for a product on the product details page was not possible for users
- The 3D viewer was not working for hidden files on the product details page.
- When you had a quote in the title, description or tag on the model upload form, the quote was doubled when you looked at the model details page.
- Shop logo's are too wide for right column
Kind regards, Arno
| Re: Shapeways site update of October 7th 2010 [message #18810 is a reply to message #18783 ] Thu, 07 October 2010 15:35 UTC |
I'm suddenly having a problem uploading models, with shapeways ignoring my selected scale and always using meters. Anyone else having this issue? Something to do with the update?
| Re: Shapeways site update of October 7th 2010 [message #18811 is a reply to message #18810 ] Thu, 07 October 2010 16:49 UTC |
I have the same problem, everything is uploaded in meters... so my designs are refused because they measure 32 m...
| Re: Shapeways site update of October 7th 2010 [message #18812 is a reply to message #18783 ] Thu, 07 October 2010 17:00 UTC |
yes I have this issue too. I had to scale my model down super tiny in autocad and then export it. I was doing everything right, and as usualy designing in mm, exporting the stl, and uploding the stl to shapeways using the mm button.
as a temporary fix i scaled my object down 1000 times in autocad and then it worked with shapeways, but its definitely a problem on shapeways's side
www.Custom3dStuff.com
| Re: Shapeways site update of October 7th 2010 [message #18814 is a reply to message #18812 ] Thu, 07 October 2010 17:29 UTC |
Thanks for the responses, guys, I was wondering if I'd lost my mind or something, because I was SURE I wasn't doing anything different.
| Re: Shapeways site update of October 7th 2010 [message #18816 is a reply to message #18814 ] Thu, 07 October 2010 17:48 UTC |
Thanks for all the feedback and sorry for the inconvenience. We are working on a fix.
- Robert
Robert Schouwenburg
| Re: Shapeways site update of October 7th 2010 [message #18823 is a reply to message #18814 ] Thu, 07 October 2010 19:52 UTC |
Hi KSND,
are you sure you didn't saved your part in inches?
I looked at the last version of
'JagerMech for Stereolithography Posed (1 285th, in).stl' in minimagics (2.0) and got a warning at opening that your part is very small and might be in inches instead of mm.
If I can convert it then to mm it uploads fine.
If I take that original last version file and upload it in inches it also uploads fine.
If thats not the case, please send me the file so I can take a look at it to see what's going on:
barry@shapeways.com
I also tried a model file of my own that I uploaded before the release in mm, and now after the release it still uploads ok in mm.
Barry
| Re: Shapeways site update of October 7th 2010 [message #18827 is a reply to message #18823 ] Thu, 07 October 2010 20:17 UTC |
Barry,
My part is saved in inches, the problem is that when I select "inches," it's getting upsized. I keep getting the message that my model is too large: "The size is 144.00 x 118.75 x 177.95 cm / 56.69 x 46.75 x 70.06 inch."
So the model is supposed to be 1.77 inches tall, but it's coming out to 1.77 meters tall even though I'm selecting inches on the upload screen. It worked yesterday for my last successful upload, and the only difference between that version and the one I'm trying to upload now is a minor variation on the pose.
| Re: Shapeways site update of October 7th 2010 [message #18830 is a reply to message #18829 ] Thu, 07 October 2010 21:38 UTC |
Glad mm is working, still not working for me with inches =/
I'll try mm in a bit.
EDIT: mm still doesn't work for me, I have to use full meters
[Updated on: Thu, 07 October 2010 22:19 UTC]
| Re: Shapeways site update of October 7th 2010 [message #18836 is a reply to message #18830 ] Fri, 08 October 2010 03:25 UTC |
Same problem here. Glad I looked at the forums before freaking out..
| Re: Shapeways site update of October 7th 2010 [message #18838 is a reply to message #18836 ] Fri, 08 October 2010 06:42 UTC |
Yesterday it seemed to work once, I could update one of my models.
Today I've tried to update another (in mm) and I have got the same error (it went in meters).
| Re: Shapeways site update of October 7th 2010 [message #18840 is a reply to message #18838 ] Fri, 08 October 2010 08:50 UTC |
The problem was with the update model form instead of the normal upload form. It indeed did not take the scale factor.
It's fixed now.
Barry
| Re: Shapeways site update of October 7th 2010 [message #18846 is a reply to message #18840 ] Fri, 08 October 2010 15:33 UTC |
Thanks, Barry, seems to be working now.
| Re: Shapeways site update of October 7th 2010 [message #18915 is a reply to message #18844 ] Mon, 11 October 2010 11:15 UTC |
1.
You don't see the markup for your own products in the price, because you don't pay markup when you buy your own model. If you log out, you can see the price has increased with the markup.
I can see the model cost $10.18 now, which seems incl markup.
2.
The full color sandstone isnt available because your model is not a color model. Then sandstone should be available, but that was selected on the restriction list.
| Re: Shapeways site update of October 7th 2010 [message #18916 is a reply to message #18890 ] Mon, 11 October 2010 11:36 UTC |
It could have been that the server was a little busy and had some delay in updating the price to be visible.
It does show correctly now as $33.
The last few hours, the server was very busy again and some model uploads/price cache updates could have some delay. We are working to minimize that delay.
| Re: Shapeways site update of October 7th 2010 [message #18918 is a reply to message #18783 ] Mon, 11 October 2010 12:24 UTC |
Because it's listed as jewelry.
