Merging STLs?
icon5.gif  Merging STLs? [message #17875] Thu, 16 September 2010 17:35 UTC Go to next message
avatar rythwi  is currently offline rythwi
Hi
I have created a model that wont merge in the old program I am using to build.
So its in two parts. Is there a way to create two STL files and then merge them together in another program? Or does anyone else know another way to merge two parts?
The way I built my object is retarded and I dont have the time to re-build it all.
Thanks for the help
Ryan
Re: Merging STLs? [message #17893 is a reply to message #17875 ] Thu, 16 September 2010 19:00 UTC Go to previous messageGo to next message
I haven't actually tried this, but I see no reason you couldn't import both of them into the same Blender session and (optionally) merge the meshes. You don't even need to merge the meshes, really; you can just select them both and export them together.
Re: Merging STLs? [message #17897 is a reply to message #17893 ] Thu, 16 September 2010 19:13 UTC Go to previous message
OK
I tried to select both and export together.
When i uploaded to shapeways it only showed one part.
But then i opened the STL in meshlab and resaved....that did the trick.
Thanks for your reply
Previous Topic:What is a winding error and how do I fix it??
Next Topic:AutoCAD2009 issue
