Home » Support » 3D Design » object resizes on export
object resizes on export [message #17581] Sat, 11 September 2010 23:29 UTC Go to next message
avatar berky93  is currently offline berky93
I have an object I am creating that should be a few inches wide. Before exporting from 3ds max I confirmed the size. But after I export both netfabb and shapeways tell me the model is less than 3mm wide. Is there a way to prevent this? I've never had this issue before with any other objects.
Check out my new shop Illogical!
Re: object resizes on export [message #17583 is a reply to message #17581 ] Sun, 12 September 2010 00:43 UTC Go to previous messageGo to next message
avatar Shuggster  is currently offline Shuggster
3ds max seems to always mess the scale up for me on export, all I do is make a note of what the largest dimension is supposed to be and then divide that number by what the largest dimension reads out as in netfabb and use that as a scale factor with the scale tool in netfabb.
Its a bit of a pain really but it works.
Re: object resizes on export [message #17589 is a reply to message #17583 ] Sun, 12 September 2010 04:31 UTC Go to previous messageGo to next message
hmmm I've never even used any tool in netfabb except repair. Good idea.
Re: object resizes on export [message #17594 is a reply to message #17589 ] Sun, 12 September 2010 12:35 UTC Go to previous messageGo to next message
I always assume 1 MAX unit = 1mm
This seems to work for me?
Duann Scott
Re: object resizes on export [message #17599 is a reply to message #17594 ] Sun, 12 September 2010 16:35 UTC Go to previous messageGo to next message
Well it never works for me Smile
Re: object resizes on export [message #17606 is a reply to message #17599 ] Sun, 12 September 2010 20:17 UTC Go to previous messageGo to next message
Shapeways Crew
I used to have a similar problem.
Please check this topic to see the solution that worked for me. I hope it will work also for you.
Re: object resizes on export [message #17614 is a reply to message #17606 ] Mon, 13 September 2010 03:37 UTC Go to previous messageGo to next message
I never work in max units, especially when I'm creating an object for print.
And thanks for the link, I think that's my problem.
Re: object resizes on export [message #17622 is a reply to message #17614 ] Mon, 13 September 2010 06:22 UTC Go to previous messageGo to next message
Shapeways Crew
It seems that 3DS Max has some display (or working) units and some internal (or actual) units.
Let us know If this solve your problem: it is at least the 3rd or 4th time someone complains about wrong export sizes with 3DS Max, so perhaps this has to be mentionned in the appropriate tutorial, if it is not already the case.
Razz
Re: object resizes on export [message #17800 is a reply to message #17581 ] Wed, 15 September 2010 19:21 UTC Go to previous messageGo to next message
It works so long as I use mm as display units in max, when I change to cm display units its then out by a factor of 10, still its a lot easier to deal with knowing I can just scale by a factor of .1 in netfabb for all objects.
Re: object resizes on export [message #17801 is a reply to message #17800 ] Wed, 15 September 2010 19:55 UTC Go to previous message
Shapeways Crew
Yes, I assume that display units and internal units must be the same to avoid any scaling at export.
Previous Topic:Mixed Media
Next Topic:An example of hinge
