I tried letting them soak in a jar of Simple Green for a few minutes, then for a day before scrubbing them with a toothbrush. It didn't really do anything that I can tell, though I might have buffed some material off the horse's back due to trying rather hard.
I'm honestly still even learning the vocabulary of painting, printing, casting, and cleaning. I need a no-experimentation method to start with, something that just works with acceptable results, then I'll delve more into all this tweaking and messing around everyone does here on the forums if I find myself heading that way. On a side note, I'd eventually like to try messing with cheaper molds so that I can make larger prints of my models and duplicate them more affordably and with better materials. That's yet another introduction I'm on the lookout for if anyone knows where to look. Large prints of strong flexible rely on my ability to paint them nicely and I'd much rather have a clean hard surface cast since painting's not my thing (yet).
In general, from what I understand for these FUD prints (correct me where possible), you usually start by
cleaning the model to remove the oil and wax residues left behind during production (dishwashing detergent, acetone, isopropyl alcohol, paint thinner, Bestine, baking it in an oven, scrubbing, etc.), then optionally finish
curing the material (I assume this is like cooking your meat all the way through but with UV light and resin), before
sealing the material with a varnish/lacquer coat to keep anything left over from any of the previous processes from interacting with the outer layer of paints as well as to protect the model from weathering. The sealing process sounds like it then doubles, in this case, as a
priming stage which can be followed by
painting and, finally, a
surface gloss/matte coat using the same sealant as before. I think there are also numerous other surface treatments like buffing and detailing passes that would fit in before the sealing as well.
I've really only looked through a handful of the FUD threads on the forums but there's a ton of different answers and approaches to the cleaning, sealing, and painting stages. Sometimes these methods sound incredibly contrived and require a studio full of supplies while other times they're as simple as raiding your broom closet. I also realize that most of the actual knowledge for these things is probably out in model figurine/train/plane/etc. forums which have been doing this stuff for ages (I haven't started searching outside these forums yet though). I also see people swearing by their particular solutions but more often than not I suspect their preferences are out of familiarity with a reliable product than because they've thoroughly tested and compared everything on the market. I won't have an eye for which varnishes hold the longest or shine the clearest or stick the best for awhile yet so basics is what I'll hopefully aim for.
I'm going to list out a few of the options I've found (so far) to clarify what I know and whether they work or not. At the moment, the ones with the least amount of fuss and most useful/affordable solutions (model specific brands likely being the most expensive?) seem to be Bestine for the cleaning and Future Floor Polish for the coating and sealing. A lot of the rest seems to be for fancier, more focused results which I wouldn't even recognize. I also prefer them because I have good reason to believe they'll work on FUD in particular (rather than guessing).
Cleaning:
Dishwashing Detergents (Simple Green) - This is mentioned as part of pretty much every cleaning method I found. I guess they work because they break down paints and other non-resistant layers from surfaces over a period of hours but are much much more gentle than the paint thinners and whatnot.
Paint Thinners (Acetone specifically) - Apparently a more heavy-handed approach to stripping layers of paint and unwanted materials from a model before working with it. This is then followed with the standard soap soak above. Paint thinners are solvents that break down various different types of paints. It sounds like
different paint thinners are ideal for different substances that need to be removed as they each have different strengths or are more or less volatile around certain materials. Acetone was the only one I saw mentioned here though.
Bestine - This (another paint thinner I assume) was mentioned more than once as a standard solution for cleaning. Soak for a day, then let the model dry for a week I guess. I've also read that this and other solvents will leak into porous materials like the Strong Flexible plastics and seep out continuously after that.
Poly S Plastic Prep - I don't know whether this is both cleaning and sealing but it's another variation and it has its own instructions on the store page. It's apparently discontinued but I've got the tab open so I must of read it somewhere around here and written it down.
Isopropyl Alcohol (91-99%?) - Not entirely sure on the application of these but I definitely saw them mentioned a few times as cleaners.
Ultrasonic Cleaner - I assume this uses vibrations to shake loose anything soft. It sounds like a magic solution for those who have access to one.
Baking it in an Oven - This is what Shapeways recommended to me. I have no idea if it works and almost no instructions either. I was told to bake it at 60 degrees (celsius I assume) but to avoid 70 degrees because that's when the model will become brittle. I don't know how long to bake it or how to remove the heat softened wax safely. I don't know how to hold the model without breaking it or burning myself either. If anyone's tried this, I'd be grateful to know how it went. If I can't get my models cleaned nicely, I might just nuke one of them as a test, though some control to the experiment would be helpful I suppose.
Coating/Sealing:
Pledge Floor Care Multi-Surface Finish - This is the current name of the future polish you mentioned. It's supposed to have the same ingredients and whatnot but it looks like there's a "3X Cleaning Power" and "2X More Shine" version so I guess it might be a bit of a mix. With what little I know, it sounds like a lot of the people who think it doesn't work as well are reacting more to a change of habit than anything else. Kind of a "things used to be easier" mentality. I haven't looked enough to find any other perspectives but this seems really accessible since it pops up at Walmart and Home Depot when you search it online.
IPP Super Clear Gloss - A Korean product that obviously works for the coating process. It was referenced for use on sandstone and I don't know if it said anything about sealing as well. I would imagine hobby shops and specifically targeted products like this would be more expensive (I bought a tiny bottle of turpentine from an art store. Never again), though they'd certainly be more reliable placebos. This shop has gloss and matte variations as well.
Is it important or recommended to do another coat of varnish over the paint to both lock the paint and give the surface a gloss/matte as well? It sounds like some people add several layers for other materials.
Anyway, I'll keep looking. It seems like I should have had some of these concepts made available by Shapeways since they are not just a hub for modelers and print makers but also for customers passing by who have no idea that FUD requires all this extra work. Curiosity seekers ought not to have such a hard time with these things.
