Home » Support » 3D Design » Remove nonmanifold faces
Remove nonmanifold faces [message #16707] Thu, 26 August 2010 11:12 UTC Go to next message
avatar bobbob12  is currently offline bobbob12
Hi
Most of the models I produce encounter an error of having nonmanifold faces.
1. Can I prevent if from happening (I use 3DMAX)?
2. I understand Meshlab can help, but I didn't find how to do it in Meshlabs
Re: Remove nonmanifold faces [message #16712 is a reply to message #16707 ] Thu, 26 August 2010 11:27 UTC Go to previous message
Could you elaborate a bit on your modeling methods?
Do you use booleans or just simple overlapping objects?
In max you can try to weld very close vertices.
And be sure to use the STL check modifier to locate mesh errors.
Slap an edit poly modifier on top and the errors are preselected.
In meshlab: patiently search the extensive filter menu for things like : weld close vertices, remove non-manifold faces etc.
Stijn
Previous Topic:texture issue
Next Topic:Models with multiple parts?
