I would like to suggest adding sheet metal to your services Many times I need something thinner than you can print. Having a laser cut piece of sheet metal would fill the bill, even if I have to make the bends. Prototype runs are expensive and most shops do not want to do them (unless there is a big pending order attached). If we could combine a bunch of designs on one machine setup (same material) then the shop could justify the run. There is a shop I work with now that may be interested. Happy to hook you up. Thanks, Bob V
Bob, That's not a service we're looking to venture into. There is a service that does sheet metal cutting (they also provide 3D printing so I can't link you) But if you search laser cutting, you should be able to find them. But come to us for 3D printing of course.
