Home » Community » 3D modelers for hire » CG artist with Full Body 3D scanner available (NL)
icon3.gif  CG artist with Full Body 3D scanner available (NL) [message #16484] Sat, 21 August 2010 16:49 UTC Go to next message
avatar tristan_bethe  is currently offline tristan_bethe
A while back I created a 3D scan studio here in Alkmaar, The Netherlands for another project I am currently working on.
I am able to do a full body 3D scan using the 3 point Creaform3D scanner
Also very small object can be scanned using a NextEngine Laserscanner
For some examples visit:
http://3dpersons.com/
Please contact me if you need something digitized or have any questions regarding the process or its possibilities.
Because of the nature of 3D scanning this will probably apply most to people living in the Netherlands.
  • Attachment: aj001_4.jpg
    (Size: 999.28KB, Downloaded 147 time(s))
See more of my 3D scanning/printing adventures here: http://3dpersons.com/ or statyou.com
Re: CG artist with Full Body 3D scanner available (NL) [message #16555 is a reply to message #16484 ] Mon, 23 August 2010 11:56 UTC Go to previous messageGo to next message
Nice! What kind of price range are we talking about for a scan?
Is the studio fixed, or mobile? (As in, could you visit us and scan the team? Wink
Re: CG artist with Full Body 3D scanner available (NL) [message #16565 is a reply to message #16555 ] Mon, 23 August 2010 12:51 UTC Go to previous messageGo to next message
Smile It used to be mobile. But I kind of immobilized it by almost fusing it to the room.
I could pack it all in and set it all up in Eindhoven if it involved enough people to make it worth the effort and if you have atleast a 4x5 meter space free to set it all up in.
And price is a bit variable. A textureless scan is much quicker to post process than one with decent textures. (since it is a mobile setup normally it is not exactly a push of a button affair to get a full scan)
The scanners do make a texture but it is pretty poor quality wise so during the scan I take separate hi res photos and paint them on the scans afterwards.
Unfortunately I am still unable to print a colored version of a mini-me trough the shapeways servers due to the wrl/small scale/to many point issue. so maybe having you own scans would be a great incentive to figure out a solution? Twisted Evil
Price range goes from 300 - 1400 euros a person depending how detailed it need to be.
Would be cool if the next material sample pack would consist of the Shapeway action figures in different materials Razz
Re: CG artist with Full Body 3D scanner available (NL) [message #16593 is a reply to message #16484 ] Tue, 24 August 2010 01:33 UTC Go to previous messageGo to next message
That is a huge scanner, sounds like fun...
Duann Scott
Re: CG artist with Full Body 3D scanner available (NL) [message #16601 is a reply to message #16593 ] Tue, 24 August 2010 07:21 UTC Go to previous messageGo to next message
Well actually It is a pretty portable scanner if you use it as they advertise: http://www.creaform3d.com/en/pdf/mega-capturor_Brochure.pdf
It came with 3 very nice flight cases. But since my primary use did not involve lugging it around I build some Wooden stands so they stand rock solid without the need to re-calibrate when I accidentally bump it when it is on a tripod.
Film studios often use these scanners on location since the normal huge scanners they use (like the cyberware scanners) cost more to ship half way around the world then the creaform3d scanners and just put it on a plane.
But you are right it is kinda fun to have fun to have a digital mini-me Cool
Re: CG artist with Full Body 3D scanner available (NL) [message #16604 is a reply to message #16565 ] Tue, 24 August 2010 09:08 UTC Go to previous messageGo to next message
If you want, I can take a look at a scanned model for you.. Did you try any polygon reduction with tools like MeshLab?
Re: CG artist with Full Body 3D scanner available (NL) [message #16606 is a reply to message #16604 ] Tue, 24 August 2010 09:34 UTC Go to previous messageGo to next message
Thanks, You actually allready checked my model last week. Check you inbox at 16 augustus 2010 15:09 Smile
I did allready optimized the model in 3ds max in my case. I always check the models in meshlab to check if the 3ds max check checks out and it always does.
Since the problem is that due to the scaling all the points get merged into one and you get an non manifold issue I tried to make an over optimized version that would look pretty poor if it actually went trough the server but that one also did not.
I sort of gave up and asked a local 3d printing company to do it but it will cost me 5 times more than when printed at shapeways (if it worked)
I think the color prints I do see have very little vertexes or are really huge?
being able to upload in mm in stead of 0.18 for an 180mme model should do the trick I guess.
Does it matter if I tick the mm radio button when uploading .wrl files by any chance? That would explain it but I thought I read somewhere that only applied for STL files.
I think I would have quite some people wanting to order a 3D statuette of them self if this would work. But my experiments are a bit at a dead end right now. Oh and painting the white and flexible models is really really hard Smile
Re: CG artist with Full Body 3D scanner available (NL) [message #16607 is a reply to message #16606 ] Tue, 24 August 2010 10:14 UTC Go to previous messageGo to next message
Ah! I have the memory of a shrimp Smile
The millimeter setting applies only to STL models, yes. We're aware of the calculation accuracy problem with VRML files and are working on a solution. We *think* it's a rather easy fix for us but then again, computer often prove otherwise Wink
Re: CG artist with Full Body 3D scanner available (NL) [message #16608 is a reply to message #16607 ] Tue, 24 August 2010 10:25 UTC Go to previous messageGo to next message
Ah cool! Could you give me an update when you found a fix. Then I can leave it to rest for now.
Any rough ETA? Is it months of or weeks?
Thx
Re: CG artist with Full Body 3D scanner available (NL) [message #16609 is a reply to message #16608 ] Tue, 24 August 2010 10:44 UTC Go to previous messageGo to next message
<cough!>weeks!<cough!>
Don't tell software development I said that Wink
Re: CG artist with Full Body 3D scanner available (NL) [message #16611 is a reply to message #16484 ] Tue, 24 August 2010 12:28 UTC Go to previous messageGo to next message
<cough!> stealing this poor guys thread (tsk tsk Bart) <cough!> Well I guess it wouldn't be stealing more running off topic.
Too bad I'm poor and live in the US. I'd love a 3D scan of myself. So everyone could print me and bask in my beauty.
[Updated on: Tue, 24 August 2010 12:35 UTC]
Re: CG artist with Full Body 3D scanner available (NL) [message #16612 is a reply to message #16611 ] Tue, 24 August 2010 12:32 UTC Go to previous messageGo to next message
well,,, it's a small investment,, but i think everbody would love to have a miniature Jettuh Embarassed
Re: CG artist with Full Body 3D scanner available (NL) [message #23744 is a reply to message #16484 ] Sat, 12 February 2011 12:56 UTC Go to previous messageGo to next message
avatar markturu  is currently offline markturu
This is an old post, but I try to ask anyway.
What do you think about NextEngine? I have been
thinking about to buy it, but I don't have previous experience
about 3D scanners.
Re: CG artist with Full Body 3D scanner available (NL) [message #23747 is a reply to message #23744 ] Sat, 12 February 2011 13:50 UTC Go to previous message
I am very happy with my Nextengine scanner it is a breeze to use, the software is very simple and streamlined and the scanning is very detailed. Do you have any specific use in mind?
Previous Topic:Expert 3D Modeler can help you with any possible and impossible project
Next Topic:Freelance site for Shapeways
