| Removing Printing Powder from WSF [message #14747] Wed, 14 July 2010 20:57 UTC |
Ahoi,
I had an object printed that is quite like a morel - inside it's hollow and the morel holes connecting to the outside are about down to 1 mm.
(it's this one: http://www.shapeways.com/model/133975/yagcoupon2____.html)
So the Shapeways Airgun cannot blow out all the powder. I had some fun with the following experimentum:
-Pouring some loose powder in a glass of water: it swims up and makes clusters - no way to simply wash it out!
-Adding some detergent: it fairly seems to "dissolve" in water.
So I did some picking, poking, drenching, and shaking and it seems I got rid of quite a lot of the powder - just one hr fun or so
For the rest I found a place to use an enforced pressure water jet that did the preliminary finish.
Although this fairly works I'd be curious if somebody else found a way to comfortably and efficiently get rid of "stuck" powder.
Edited to remove typos
[Updated on: Wed, 14 July 2010 21:46 UTC]
| Re: Removing Printing Powder from WSF [message #14748 is a reply to message #14747 ] Wed, 14 July 2010 21:08 UTC |
I once used a tooth cleaning water jet to get rid of some stubborn powder.
As a side note, I use boiling soapy water to get rid of powder that isn't actually trapped but does still need removal (usually, the objects are still quite powdery when I receive them).
| Re: Removing Printing Powder from WSF [message #15209 is a reply to message #14748 ] Sun, 25 July 2010 20:48 UTC |
Thank you TomZ,
tried that too but it all did leave the powder in place where it was stuck somewhat hidden.
The finally best result for the object in question I achieved with some patience and a semi direct wood based rod average distance bendable multiple acting fur device - aka paintbrush, poking, and twisting. With the brush I also was able to remove the powder from areas that weren't reachable directly (but close to that).
So this is no help if the powder in deep inside a structure, but for all areas close to where you can see, I would recommend a (small) brush.
Well, not really HiTec and maybe a reader's first thought - just wanted to share anyway as sometimes the simple things don't come to mind in time ...
[Updated on: Sun, 25 July 2010 20:51 UTC]
