Exporting wrl color in blender
Exporting wrl color in blender [message #14166] Thu, 01 July 2010 09:33 UTC Go to next message
avatar sublimate  is currently offline sublimate
I can export the "A" and the wrl file has the image information, but when i export the "R" (using the same material) the wrl file doesn't include the image. What am i doing wrong? Using Blender 2.49.
  • Attachment: HELP.blend
    (Size: 207.58KB, Downloaded 171 time(s))
Re: Exporting wrl color in blender [message #14188 is a reply to message #14166 ] Thu, 01 July 2010 13:11 UTC Go to previous messageGo to next message
Open the WRL with notepad. Go down to where it will say something like
material DEF MA_Material Material {
diffuseColor 1.0 1.0 1.0
ambientIntensity 0.0666667
specularColor 0.0004008 0.0004008 0.0004008
emissiveColor 0.0 0.0 0.0
shininess 0.2011719
transparency 0.0
Following that will be
In between them put this
texture ImageTexture { url "yourfile.jpg" }
replacing yourfile, with your texture file.
Re: Exporting wrl color in blender [message #14225 is a reply to message #14166 ] Thu, 01 July 2010 19:32 UTC Go to previous messageGo to next message
In Blender, the best way is to delete the materials, but keep the UV mapping. Press F9, you should see "UV Texture ... New" with one named "UVTex" below (you can change this default name and use multiple maps but then you have to make sure the right one is active). That is what matters for image based .wrl and Shapeways.
To clean up the render materials: delete them in F9 where it says 1 Mat 1, it should say 0 Mat 0, so press the button Delete that's below. And F5 buttons should show no materials linked, if you did it right. Then exporter will work without any manual tweaks about materials.
These're the lines I got when exporting your .blend, which is wrong:
appearance Appearance {
   ambientIntensity 0.1666667
   specularColor 0.0008008 0.0008008 0.0008008
   shininess 0.9980469
   transparency 0.0
 material USE MA_Material
 texture DEF charmpic5_jpg ImageTexture {
  url "charmpic5.jpg"
With your .blend I think it works for one object because it puts a material definition in one object and a reference to it (instead of the full material def again) plus the image in the other object, and Shapeways ignores that reference.
Youknowwho4eva suggests to fix it by hand, but if you do it right in Blender it should show:
  url "charmpic5.jpg"
  url "charmpic5.jpg"
I tried exporting it to verify, but it failed. Only one letter has image (the other has empty appearance block)... which leads us to another thing you've to do: select the R, enter edit mode and select vertices, select the image in image window so the vertices are associated to it.
So summing up: no render materials linked (in F9, 0 Mat 0), right UV texture active (F9 again, one UV Texture at least, it'll be created when you unwrap if needed), all faces associated to images (image area shows right one while you select things in edit mode).
Re: Exporting wrl color in blender [message #14243 is a reply to message #14225 ] Fri, 02 July 2010 01:41 UTC Go to previous message
Got it working. Thanks for the help.
Previous Topic:Win a free SketchUp eBook
Next Topic:weird looking stl
